BPM on Job Entry
Sometimes there is a problem with Adapters. I mean that you'll not be
able to catch AdapterMethod for each adapter in Vantage. Some of
them are NOT raising an event because they were codded that way.
The good example here could be a DefaultJobNum method within LaborEntry
adapter. I was trying to use a MessageBox.Show statement in
AfterAdapter method. The trace log was showing that method was executed
but MessageBox.Show statment was never executed.
Vantage BUG - another :)
PLEASE USE 'Reply to ALL' functionality - so I don't need to search
through all new posts in Vantage group to be able to answer your
question
regards
Grzegorz Szczepański
Dnia Wed, 20 May 2009 13:40:40 -0700 (PDT)
Robert Brown <robertb_versa@...> napisał(a):
> Try testing for JobProd.ProdQty = 0 instead? (JobHead.ProdQty is
> derived from this unless you are making multiple parts on the Job -
> then you'd have to look at the appropriate field(s) in JobPart table).
> Also -Â The JobEntry adapter has a GetDetails method - but essentially
> all it does is launch another Form/Application... I wonder if this
> somehow complicates things (from a BPM perspective).
> Have you tried doing this via a Job Entry client VB customization
> (BeforeAdapterMethod would be event trigger type)?
> Some things are easier to do on the client side than server side (via
> BPM) - and vice-versa.
> Good luck with it.
> Rob
> From: melissa hietala <kevmel822@...>
> To: vantage@yahoogroups.com
> Sent: Wednesday, May 20, 2009 12:49:44 PM
> Subject: [Vantage] BPM on Job Entry
> I am attempting to create a BPM that will not allow a user to "Get
> Details" when the  JobHead.ProdQty = 0. I have been down a few
> different routes and haven't been able to get anything to work. Does
> anybody have any thoughts on how this could be accomplished?
> Thank you,
> Â Dustin Biniek
> UMC, Inc.
> DustinB@ultramc. com
I am attempting to create a BPM that will not allow a user to "Get Details" when the  JobHead.ProdQty = 0. I have been down a few different routes and haven't been able to get anything to work. Does anybody have any thoughts on how this could be accomplished?
Thank you,
 Dustin Biniek
UMC, Inc.
DustinB@...
Try testing for JobProd.ProdQty = 0 instead? (JobHead.ProdQty is derived from this unless you are making multiple parts on the Job - then you'd have to look at the appropriate field(s) in JobPart table).
Also -Â The JobEntry adapter has a GetDetails method - but essentially all it does is launch another Form/Application... I wonder if this somehow complicates things (from a BPM perspective).
Have you tried doing this via a Job Entry client VB customization (BeforeAdapterMethod would be event trigger type)?
Some things are easier to do on the client side than server side (via BPM) - and vice-versa.
Good luck with it.
Rob
Thank you,
 Dustin Biniek
UMC, Inc.
I was wondering the same thing..i did a quick trace on the process and
wasn't seeing any data in the jobentry dataset, so youd have a little
trouble setting any criteria based on ttjobhead.
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site)
Of Robert Brown
Sent: Wednesday, May 20, 2009 3:41 PM
Subject: Re: [Vantage] BPM on Job Entry
Also - The JobEntry adapter has a GetDetails method - but essentially
Good luck with it.
Rob
<mailto:kevmel822%40yahoo.com> >
Thank you,
Dustin Biniek
UMC, Inc.
