That worked. I didn't need the ClassID.
Thanks!!!!
Patty Buechler
Thanks!!!!
Patty Buechler
--- In vantage@yahoogroups.com, "vantage" <vantage@...> wrote:
> Patty,
> Â
> I am doing this same setup however you do not need ClassID and
> ClassDescription. I and looking at the PODetail.CalcTransType and
the
> PODetail.ClassDescription fields to fire the exception. If the
line is
> purchase to job the CalcTransType will be PUR-MTL. You may want to
delete
> the BPM and recreate it to see if this fixes your problem.
> Â
> Conditions : the PODetail.CalcTranType field of the changed row is
equal to
> the "PUR-UKN" value
> and the PODetail.ClassDescription field of the changed row is equal
to the
> "" value
> Â
> Â
> Steve
> Â
> -----Original Message-----
> From: bpbuechler [mailto:pbuechler@...]
> Sent: December 04, 2008 9:30 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: BPM PO.Update: I want to raise an exception
when the
> Part Class = "" (8.03.405)
> Â
> Okay...so I took your suggestion and I kept the table for the
> conditions to ttPODetail.
> So now it looks like the following:
> the PODetail.CalcJobSeqType field of the changed row is equal to
> the "PUR-UKN" value
> and the PODetail.ClassID field of the changed row is equal to
the ""
> value
> or the PODetail.ClassDescription field of the changed row is equal
to
> the "" value
> It still does not work...Help?
> BTW...we are on 8.03.405
> Thanks
> Patty Buechler
> --- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@>
> wrote:
> > Hi Patty,
> > I'm open to correction on this - I'm still getting to grips with
> BPMs
> > - but I don't think you can include more than one "tt" table in a
> > query or in BPM 4GL code. My understanding is than when you save
a
> > PODetail line, the ttPODetail table is cleared. So if you then
add
> a
> > Release, you're now working off the ttPORel table and you'll have
> to
> > link this table to the saved PODetail table.
> > HTH,
> > Nigel.
> > --- In vantage@yahoogroups.com, "bpbuechler" <pbuechler@> wrote:
> > > I have created a BPM around the PO.Update to raise an exception
> > when
> > > the PORel.TranType field of the changed row is equal to
the "PUR-
> > UKN"
> > > value and the PODetail.ClassID field of the changed row is
equal
> to
> > > the "" value or the PODetail.ClassDescription field of the
> changed
> > > row is equal to the "" value
> > > My problem is that I only want to raise the exception when
> the "Buy
> > > For" is OTHER.
> > > So I added one more condition where the ttPORel.TranType = "PUR-
> > UKN"
> > > and it still raises the exception if the "Buy For" is a Job.
> > > I see there are a couple fields in related tables
> > > (ttPODetail.CalcTranType & ttPORel.JobSeqType). So I added
those
> > too
> > > and it still didn't work as I need it to.
> > > Any thoughts/suggestions?
> > > Thanks
> > > Patty Buechler
