DCD-USERID is a system variable so it doesn't need the table name.
Try using STRING(DCD-USERID).
Of Dines, Tim
Sent: Thursday, September 16, 2010 9:42 AM
Subject: RE: [Vantage] BPM Question On Current User
What table is DCD-USERID located in? You need the table name just like
on the other side of the equation unless you declare a variable and put
the DCD-USERID value into it first.
Tim Dines
ERP Analyst
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Behalf
Of melissa hietala
Sent: Wednesday, September 15, 2010 11:24 AM
Subject: [Vantage] BPM Question On Current User
I have a BPM setup on the method "UD100.GetByID". I have a post
processing
directive I am attempting to setup utilizing the "number of rows in the
designed query is not less than 1" condition. What I need to do is
after the
"GetByID" method is launched, I need to take the value that is in the
ttUD01.ShortChar01" field and compare it to the ID of the user that is
currently
logged in (I believe the syntax for this is "DCD-UserID"). So I am
attempting
to enter the following code into the condition:
for each ttUD100 where ttUD100.ShortChar01 = DCD-UserID no-lock
However I am receiving an error stating: "DCD-UserID must be a quoted
constant
or an unabbreviated, unambiguous buffer/field reference for buffers
known to
query . (7328)"
Any thoughts on what I am doing wrong or how I can get this corrected?
Thanks for your help,
Dustin Biniek
Of Dines, Tim
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Behalf
Of melissa hietala
processing
after the
currently
attempting
constant
known to
query . (7328)"
Dustin Biniek
