BPM - Receipt Entry
The trace is using the Receipt.Update method. I'm still trying to figure why there is a discrepancy between environments that could be causing the issue since I have it working on another environment.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Scotty K.
Sent: Tuesday, July 16, 2013 10:01 AM
Subject: Re: [Vantage] Re: BPM - Receipt Entry
Have you tried the PreUpdate or UpdateMaster methods?
Run a trace to see excectly what method is being called.
On Tue, Jul 16, 2013 at 9:34 AM, Chang, Chia <cchang@...> wrote:
> The code works because I've tested it in our other company's test
> environments using standard Epicor method directive. The BPM's are all
> created within the Method Directive Maintenance screen. We do have
> some custom ABL BPM codes within Receipt Entry but I'm not sure if
> those are causing the issue too but I've tried disabling them already.
> It's a simple BPM for testing purposes but it is still not triggering
> correctly. The Pre-Processing setup is below.
> Pre-Processing (Receipt.Update)
> Condition: the ttRcvHead.ImportNum field has been changed from any to
> any
> Actions: raise exception based on the Receipt Error template
> Behalf Of Amélie Pelletier
> Sent: Tuesday, July 16, 2013 8:56 AM
> Subject: [Vantage] Re: BPM - Receipt Entry
> Could you post your code please?
> *Amélie Pelletier*
> *Analyste Programmeur / Program analyst*
> [image: cid:image001.jpg@01CD5525.2091A820]
> *230, Boulevard Nilus-Leclerc*
> *L'Islet, Québec (Canada)*
> *G0R 2C0*
> *Téléphone: 418-247-3986 ext. 2390*
> *Fax: 418-247-7925*
> *amelie.pelletier@... <brigitte.savoie@...>*
> *P** *Est-ce nécessaire d'imprimer ce message?
> *Please consider the environment before printing this email**.*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
I have been trying to set up BPM's in Receipt Entry but none of them are triggering on the Receipt BO when enabled. When I set up BPM's in other screens using other method directives they work fine. Any thoughts on what could be causing BPM's to not trigger at all in Receipt Entry using the Receipt BO but working ok in all others?
*Am�lie Pelletier*
*L'Islet, Qu�bec (Canada)*
*G0R 2C0*
*T�l�phone: 418-247-3986 ext. 2390*
*Fax: 418-247-7925*
*P** *Est-ce n�cessaire d�imprimer ce message?
The code works because I've tested it in our other company's test environments using standard Epicor method directive. The BPM's are all created within the Method Directive Maintenance screen. We do have some custom ABL BPM codes within Receipt Entry but I'm not sure if those are causing the issue too but I've tried disabling them already. It's a simple BPM for testing purposes but it is still not triggering correctly. The Pre-Processing setup is below.
Condition: the ttRcvHead.ImportNum field has been changed from any to any
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Amélie Pelletier
*Amélie Pelletier*
*G0R 2C0*
*Fax: 418-247-7925*
> Of Am�lie Pelletier
> *Am�lie Pelletier*
> *G0R 2C0*
> *Fax: 418-247-7925*
> *P** *Est-ce n�cessaire d'imprimer ce message?
If it works in other places, I would try to display the data in that field before and/or after your code. I have run into population timing issues before that about drive you crazy.
Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Chang, Chia
Sent: Tuesday, July 16, 2013 10:34 AM
Subject: RE: [Vantage] Re: BPM - Receipt Entry
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Amélie Pelletier
*Amélie Pelletier*
[image: cid:image001.jpg@01CD5525.2091A820<mailto:image001.jpg%4001CD5525.2091A820>]
*G0R 2C0*
*Fax: 418-247-7925*
*amelie.pelletier@...<mailto:%2Aamelie.pelletier%40groupebertec.com> <brigitte.savoie@...<mailto:brigitte.savoie%40groupebertec.com>>*
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
