BPM SalesOrder.Update Post-Proc - Update Commissions Splits
We are trying to recalculate our commission splits. We are doing this on SalesOrder.Update Post-Proc BPM.
I am running into a Row modified issue in custom code so I scaled back to what I thought was a simple BPM and seem to still be getting the issue.
BPM has 2 nodes ( Custom Code, and Invoke BO Method)
Custom Code
Invoke BO Method
When I go into a sales order, make a change and hit save and them the BPM uses 1 of the 3 examples in the Custom Code example, (I.e. Test one, setting RepSplit1 = 100, RepSplit2 = 0) I get a row modified error. This is in a Post-Process on SalesOrder.Update.
I have disabled all other BPMs/Data-Directives/ and am using the base form so no other code should be getting fired.
Any Ideas?
Joe:
 Usually that error comes up when something was ‘changed and not Saved’, then ‘changed’ again then Saved , at least I think that is true-there is a ‘dirty row’ that is out there
And not handled. Is it possible that this sequence is trying to update more than once?
may i ask why you choosed to update these fields after Epicor Base, (i.e. post processing )?
