Thanks Peter,
I found a bit of a workaround although is not optimal. I start a new process
from the BPM and then sleep that process for 30 seconds then use the Visual
Studio attach to process feature to step through it.
Sincerely
Jose C Gomez
http://www.josecgomez.com
On Fri, Jul 31, 2009 at 8:34 AM, Peter Constantinidis
Sincerely
Jose C Gomez
>[Non-text portions of this message have been removed]
> Jose,
> The only way that I figured out how to debug is write to the log file where
> you installed your BPM Server. I haven't found a way to step through it in
> my local development environment. You will need to execute the BPM through
> Vantage and then go and check the log file on your BPMServer.
> The log file should be located here on the server you installed the BPM
> Server:
> C:\Program
> Files\Epicor\BPMServer\Logs\Action_Epicor.Mfg.BPM.Server.WinService.exe.log
> Here's my sample code of how I write to the log. Basically you just use the
> Trace object.
> namespace Bpm.Custom {
> using System;
> using System.Data;
> using System.Diagnostics;
> using Bpm.Action;
> public class UD100 {
> public void OnBeforeUpdate(System.Data.DataTable ttUD100,
> System.Data.DataTable ttUD100Attch, System.Data.DataTable ttUD100A)
> // TODO: Replace the throw statement with any code for an action before
> UD100.GetaNewUD100() method invocation
> Trace.WriteLine("PeteTest .NET Action Process START...");
> DataRow row = ttUD100.Rows[0];
> if (row["RowMod"].ToString() == "A")
> Trace.WriteLine("RowValue1: " + " RowState: " + row.RowState.ToString() +
> ", CreateDate: " + row["Key1"].ToString() + ", CreateUserID: " +
> row["Date01"] + " " + row["Number01"] + ": DateTime.Now=" + DateTime.Now);
> row.BeginEdit();
> FixDBNulls objFix = new FixDBNulls();
> objFix.FillDBNulls(row);
> row["Date01"] = DateTime.Now;
> row["Number01"] = 9999;
> row.EndEdit();
> Trace.WriteLine("RowValue:2 " + " RowState: " + row.RowState.ToString() +
> }//end if
> Trace.WriteLine("PeteTest .NET Action Process END...");
> }//end class UD100
> public class FixDBNulls
> public void FillDBNulls(DataRow inRow)
> Int32 iCol = 0;
> for (iCol = 0; iCol < inRow.ItemArray.Length; iCol++)
> if (inRow[iCol].Equals(DBNull.Value))
> switch (inRow.Table.Columns[iCol].DataType.ToString())
> case "System.Int32":
> case "System.Int16":
> case "System.Double":
> inRow[iCol] = 0;
> break;
> case "System.String":
> inRow[iCol] = "";
> break;
> case "System.DateTime":
> inRow[iCol] = DateTime.MinValue;
> break;
> }//end switch
> }//end if
> }//end foreach
> }//end FillDBNulls()
> }//end Class FixDBNulls
> Regards,
> Software Development Manager
> Global Packaging, Inc.
> Phone: (484) 362-2149
> Mobile: (610) 213-6322
> Fax: (484) 831-1109
> Email: pconstan@... <pconstan%40glopkg.com><mailto:
> pconstan@... <pconstan%40glopkg.com>>
> From: Jose Gomez [mailto:jose@... <jose%40josecgomez.com>]
> Sent: Wednesday, July 29, 2009 11:26 AM
> To: Peter Constantinidis
> Cc: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Subject: Re: [Vantage] Re: BPM Server .NET
> Peter,
> Thanks for all your help so far. I've got it working with a simple BPM but
> I can't figure out of there is a way to debug it. I can write the code and
> compile it and when its something simple like changing a field or something
> llike ti just runs. But if its something more complicated and it generates
> exceptions and such. It seems to jus crash even thogh I have try catches and
> others to handle exceptions. Is there a way that you know of debuging it?
> Sincerely
> Jose C Gomez
> Sent from Jacksonville, FL, United States
> On Mon, Jul 27, 2009 at 8:44 AM, Peter Constantinidis <pconstan@...<pconstan%40glopkg.com>
> <mailto:pconstan@... <pconstan%40glopkg.com>>> wrote:
> Jose,
> You will need to install the BPM Server on your local development
> environment as well. Once you do that the assembly reference you will need
> will be located here:
> C:\Program Files\ComPlus
> Applications\{CB819E8D-DF90-4B54-B72C-51787B8A5091}\Epicor.Mfg.BPM.Server.CallContext.dll
> This is the assembly you will need in order to build your project properly.
> Regards,
> Fax: (484) 831-1109
> <mailto:jose@... <jose%40josecgomez.com>>]
> Sent: Monday, July 27, 2009 8:39 AM
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com><mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>>; Peter Constantinidis
> Hi,
> Thanks for your help. I installed the BPM Server and such. But when
> creating the VS Project to make the action I can't find the BPM.Action
> reference dll. Where is that located?
> Thanks!
> Sincerely
> Jose C Gomez
> http://www.josecgomez.com<http://www.josecgomez.com/>
> On Fri, Jul 24, 2009 at 9:50 AM, petecon77 <pconstan@...<pconstan%40glopkg.com>
> There's really not that much involved in installing the BPMServer.
> The documentation is in the Vantage Help file. Just Search for BPM Server
> and you should get all the information you will need.
> This was enough to get me started.
> Check out Message #80239 and Message #80327.
> This will help you with how to actually implement an Action and working
> with the passed in DataSet once you have the BPM Server setup.
> Good Luck!
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com><mailto:
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>>, Jose Gomez
> <jose@...> wrote:
> > Hello,
> > We are trying to use BPM to modify an action on Sales Order Update we
> have
> > used BPM's through 4GL in the past we are .NET programers and we figure
> it
> > would be easier to create it using the Call .NET Method Action. But we
> can't
> > figure out how to set up the BPM Server and where to get the references
> > from.
> > Anyone have a doc or something that walks you through setting up the BPM
> > Server with an example?
> > We'd appreciate it
> > Thanks!
> > Sincerely
> > Jose C Gomez
