BPM To Auto Fill a Field
Wondering if I just create a bpm with the method I need to run and have it run after my code but its imbedded in other bpm method call or not sure if this is the best way
--- In vantage@yahoogroups.com, "gabelebron07" <gabe.lebron@...> wrote:
> Thank you for the explanation I understand what rowmod its doing now. You were absolutely right on the messages I saw the first one and not the second until I removed the Where clause. It seems to populate the field now but it populates that fields in all the lines each time -I don't seem to have an issue with that has of right now. There is a method that actually runs if you actually type a number in that field and tab out. Its not running when you auto fill. Is there a way to add a line in the code to run that method also? And I think it will work fine.
> This is the method
> <businessObject>Epicor.Mfg.BO.Quote</businessObject>
> <methodName>GetWSUnitPrice</methodName>
> --- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@> wrote:
> > Gabe,
> > What I've seen in the ABL code is this. Often times in the "pre-processing"
> > routines, you have a lot of "tt" records for each of the different records.
> > For example, if you have a PO with 5 lines, there will be 5 ttPODetail
> > records. Therefore, it's critical that you have the "where rowmod"
> > statement, so you ensure you're getting the one you need. (Actually,
> > there's often 6 records, as it will have the "unchanged" ttPODetail as well
> > as the changed one, with the changed one having a rowmod of "U", but that's
> > a different story.)
> > On post-processing, often times there's only the one "tt" record available,
> > the one that was updated. In addition, it often clears the RowMod. This
> > actually makes sense, since that's record is now updated, the "tt" is being
> > sent back to the program, and you wouldn't want the program having that "tt"
> > records being marked with an "A" or "U" rowmod.
> > So, I'd do the following. First, add informational messages within the ABL
> > code so you can ensure you know exactly what it's doing:
> > {lib/PublishInfoMsg.i &InfoMsg = " 'inside the BPM ' "}
> > for each QuoteQty where (ttQuoteQty.RowMod = 'A' OR ttQuoteQty.RowMod = 'U')
> > exclusive-lock:
> > Assign ttQuoteQty.WQUnitPrice = ttQuoteQty.Calcupcommprofit.
> > {lib/PublishInfoMsg.i &InfoMsg = " 'set value to ' +
> > string(ttQuoteQty.WQUnitPrice)"}
> > End.
> > Next, I'll assume you'll see the first message (that's outside the "for"
> > loop), but not the second one (inside the loop). If that's the case, then
> > remove the "where" clauses on the "for each" statement, and see if that
> > helps.
> > Of course, I'd ensure you do a test with a Quote line that has multiple
> > quantities set, so you can verify it's indeed only setting the WQUnitPrice
> > on the one you updated.
> > Finally, I used words like "usually" and "often" in describing Epicor's
> > handling of "tt" records. That's because as soon as you think it's working
> > a certain way, you'll find some method out there that violates the rules.
> > Why would we expect consistency in behavior?
> > Hope that helps,
> > Kevin Simon
> > SimsTrak Consulting, LLC
> > Delivering Customized Epicor Solutions
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > gabelebron07
> > Sent: Wednesday, November 14, 2012 2:19 PM
> > Subject: [Vantage] Re: BPM To Auto Fill a Field
> > I have tried some further testing and wondering if the fact that
> > CalUPCommProfit is a caulated field is the issue or that should not be a
> > problem
> > it seems to me I picked a good method call and have the BPM setup right.
> > I dont think the code is doing the switch is there a way for me to check
> > out the code and see whats it doing?
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> > "gabelebron07" <gabe.lebron@> wrote:
> > > Ok I had add tt infront of the QuoteQTY so no errors on code. I used
> > > <methodName>GetByID</methodName> as my methcode code call
> > > I know that pops up alot during quoting but its the very last thing
> > that happens after you get details. I will work on condition later.
> > > I added an informational message to make sure its working and it comes
> > up right after i get details. no issue there but the Price is still not
> > populating in WQUnitPrice from CalcUPCommProfit field Not sure what i am
> > missing
> > = 'U')
> > > exclusive-lock.
> > > End.
> > > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
> > Drecchio" vic.drecchio@ wrote:
> > > > Yep. Thanks.
> > > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> > Behalf Of
> > > > Neil Buckman
> > > > Sent: Tuesday, November 13, 2012 9:19 PM
> > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > Subject: RE: [Vantage] Re: BPM To Auto Fill a Field
> > > > where (QuoteQty.RowMod = 'A' or QuoteQty.RowMod = 'U')
> > > > The Or is missing...
> > > > - Neil
> > On
> > > > Behalf Of gabelebron07
> > > > Sent: Wednesday, 14 November 2012 1:07 PM
> > > > Ok so let me know if i am on the right track. instead of (field of
> > the
> > > > change row) I use Synchronously (execute ABL code.. record nothing.)
> > Action
> > > > Excute Code Below and enter your code? or Create a .p file add your
> > code to
> > > > that and link it to Forward to procedure?
> > > > I did try adding your code to Excute code Below and got this error
> > > > ** Unable to understand after -- "QuoteQty where". (247)
> > C:\Epicor\Epicor905\EpicorData\50012022362115144226206102202163104059180\
> > .p
> > > > Line 12 --Invalid FOR, DO, REPEAT, or EDITING statement.
> > > > if i did it right i am asuming i still need to tweak the code. i
> > know
> > > > nothing about progress code I am new to epicor. I am getting the
> > basic
> > > > function of how things work its going to take me a bit to get the
> > code down
> > > > <mailto:vantage%40yahoogroups.com>, "Vic Drecchio" <vic.drecchio@
> > <mailto:vic.drecchio@%0b>
> > > > <mailto:vic.drecchio@%3cmailto:vic.drecchio@>
> > > > <mailto:vic.drecchio@>> wrote:
> > > > > You're close. You'll need to execute 4GL code as the Action. It
> > should
> > > > > look close to this:
> > > > > for each QuoteQty where (QuoteQty.RowMod = 'A' QuoteQty.RowMod =
> > 'U')
> > > > > exclusive-lock.
> > > > > Assign QuoteQty.WQUnitPrice = QuoteQty.Calcupcommprofit.
> > > > > End.
> > > > <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com
> > <mailto:vantage%40yahoogroups.com>] On
> > > > Behalf Of
> > > > > gabelebron07
> > > > > Sent: Tuesday, November 13, 2012 3:10 PM
> > > > > Subject: [Vantage] BPM To Auto Fill a Field
> > > > > Wondering if anyone could help. I don't have an issue creating a
> > BPM to
> > > > auto
> > > > > fill a field with a certain static value
> > > > > I trying to create one using what I believe is a calculated field
> > from
> > > > > another field. To be more exact in the Quote Entry >Line
> > >Worksheet tab I
> > > > am
> > > > > trying to have the Quoted Unit Price (QuoteQty.WQunitPrice) field
> > auto
> > > > > populate with Unit Price w/Commission (QuoteQty.Calcupcommprofit)
> > field
> > > > > I created a BPM, Picked a method and added a Post Processing
> > Directive. I
> > > > > choose (set the QuoteQty.WQUnitPrice field of the change row to
> > the
> > > > > Specified Expression) Not sure how to build the expression to have
> > > > > QuoteQty.WQUnitPrice field = QuoteQty.Calcupcommprofit
> > > > > No virus found in this message.
> > > > > Checked by AVG - www.avg.com<http://www.avg.com>
> > > > > Version: 2012.0.2221 / Virus Database: 2441/5392 - Release Date:
> > 11/13/12
> > 11/13/12
> > > > > [Non-text portions of this message have been removed]
> > > > Notice:This e-mail and any attachments are confidential and are only
> > for the
> > > > use of the person to whom they are addressed. If you are not the
> > intended
> > > > recipient please advise the sender by return e-mail and delete the
> > message
> > > > and any attachments. Any use, interference with, disclosure or
> > copying of
> > > > this message or any attachments is unauthorised and prohibited. The
> > sender
> > > > does not warrant that the information is free of a virus or any
> > other defect
> > > > or error, and any views expressed herein, unless specifically
> > indicated
> > > > otherwise, are those of the individual sender.
> > > > The DH Gibson Group of Companies -
> > http://www.gibsonshopfitters.com.au
> > > > P Please consider our shared environment before printing this
> > communication.
> > > > Version: 2012.0.2221 / Virus Database: 2441/5393 - Release Date:
> > 11/13/12
> > 11/13/12
Wondering if anyone could help. I don't have an issue creating a BPM to auto fill a field with a certain static value
I trying to create one using what I believe is a calculated field from another field. To be more exact in the Quote Entry >Line >Worksheet tab I am trying to have the Quoted Unit Price (QuoteQty.WQunitPrice) field auto populate with Unit Price w/Commission (QuoteQty.Calcupcommprofit) field
I created a BPM, Picked a method and added a Post Processing Directive. I choose (set the QuoteQty.WQUnitPrice field of the change row to the Specified Expression) Not sure how to build the expression to have QuoteQty.WQUnitPrice field = QuoteQty.Calcupcommprofit
You're close. You'll need to execute 4GL code as the Action. It should
look close to this:
for each QuoteQty where (QuoteQty.RowMod = 'A' QuoteQty.RowMod = 'U')
exclusive-lock.
End.
gabelebron07
Version: 2012.0.2221 / Virus Database: 2441/5392 - Release Date: 11/13/12
Ok so let me know if i am on the right track. instead of (field of the change row) I use Synchronously (execute ABL code.. record nothing.) Action Excute Code Below and enter your code? or Create a .p file add your code to that and link it to Forward to procedure?
** C:\Epicor\Epicor905\EpicorData\50012022362115144226206102202163104059180.p Line 12 --Invalid FOR, DO, REPEAT, or EDITING statement.
if i did it right i am asuming i still need to tweak the code. i know nothing about progress code I am new to epicor. I am getting the basic function of how things work its going to take me a bit to get the code down
> look close to this:
> exclusive-lock.
> End.
> gabelebron07
- Neil
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of gabelebron07
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Vic Drecchio" <vic.drecchio@...<mailto:vic.drecchio@...>> wrote:
> look close to this:
> exclusive-lock.
> End.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> gabelebron07
Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
Yep. Thanks.
Neil Buckman
- Neil
<mailto:vic.drecchio@...%3cmailto:vic.drecchio@...>
> look close to this:
> exclusive-lock.
> End.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
> gabelebron07
auto
am
Version: 2012.0.2221 / Virus Database: 2441/5393 - Release Date: 11/13/12
I know that pops up alot during quoting but its the very last thing that happens after you get details. I will work on condition later.
I added an informational message to make sure its working and it comes up right after i get details. no issue there but the Price is still not populating in WQUnitPrice from CalcUPCommProfit field Not sure what i am missing
exclusive-lock.
End.
> Yep. Thanks.
> Neil Buckman
> - Neil
> > look close to this:
> > exclusive-lock.
> > End.
> Behalf Of
> > gabelebron07
> auto
> am
problem
missing
= 'U')
> exclusive-lock.
> End.
> --- In vantage@yahoogroups.com, "Vic Drecchio" vic.drecchio@ wrote:
> > Yep. Thanks.
Behalf Of
> > Neil Buckman
> > - Neil
On
the
Action
code to
.p
know
basic
code down
should
> > > look close to this:
'U')
> > > exclusive-lock.
> > > End.
> > Behalf Of
> > > gabelebron07
BPM to
> > auto
from
>Worksheet tab I
> > am
auto
field
Directive. I
the
11/13/12
11/13/12
for the
intended
message
copying of
sender
other defect
indicated
communication.
11/13/12
11/13/12
problem
missing
= 'U')
> exclusive-lock.
> End.
> > Yep. Thanks.
Behalf Of
> > Neil Buckman
> > - Neil
On
the
Action
code to
.p
know
basic
code down
should
> > > look close to this:
'U')
> > > exclusive-lock.
> > > End.
> > Behalf Of
> > > gabelebron07
BPM to
> > auto
from
>Worksheet tab I
> > am
auto
field
Directive. I
the
11/13/12
11/13/12
for the
intended
message
copying of
sender
other defect
indicated
communication.
11/13/12
11/13/12
Gabe,
a different story.)
exclusive-lock:
End.
helps.
Hope that helps,
Kevin Simon
gabelebron07
problem
missing
= 'U')
> exclusive-lock.
> End.
> > Yep. Thanks.
Behalf Of
> > Neil Buckman
> > - Neil
On
the
Action
code to
.p
know
basic
code down
should
> > > look close to this:
'U')
> > > exclusive-lock.
> > > End.
> > Behalf Of
> > > gabelebron07
BPM to
> > auto
from
>Worksheet tab I
> > am
auto
field
Directive. I
the
11/13/12
11/13/12
for the
intended
message
copying of
sender
other defect
indicated
communication.
11/13/12
11/13/12
This is the method
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> Gabe,
> a different story.)
> exclusive-lock:
> End.
> helps.
> Hope that helps,
> Kevin Simon
> gabelebron07
> problem
> missing
> = 'U')
> > exclusive-lock.
> > End.
> > > Yep. Thanks.
> Behalf Of
> > > Neil Buckman
> > > - Neil
> On
> the
> Action
> code to
> .p
> know
> basic
> code down
> should
> > > > look close to this:
> 'U')
> > > > exclusive-lock.
> > > > End.
> > > Behalf Of
> > > > gabelebron07
> BPM to
> > > auto
> from
> >Worksheet tab I
> > > am
> auto
> field
> Directive. I
> the
> 11/13/12
> 11/13/12
> for the
> intended
> message
> copying of
> sender
> other defect
> indicated
> communication.
> 11/13/12
> 11/13/12
