BPM to set "PODetail.QtyOption" to "Our"
I tried, no luck!
Mike Tonoyan / Natel Engr.
mtonoyan@...
Of Jose Gomez
Sent: Tuesday, May 31, 2011 1:52 PM
Subject: Re: [Vantage] BPM to set "PODetail.QtyOption" to "Our"
Are you trying to assign the string Our?? if so try single quotes and
no parenthesis.
*Jose C Gomez*
Software Engineer
*NEED HELP WITH AN EPICOR ISSUE THAT CAN NOT BE SOLVED ON THE LIST?
CHECK OUT MY NEW BLOG <http://www.usdoingstuff.com> OR CONTACT ME
DIRECTLY*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
On Tue, May 31, 2011 at 4:39 PM, Mike Tonoyan
<mtonoyan@...>wrote:
> Jose,
> I just uploaded the "PODtl_QtyType.bpm
<http://f1.grp.yahoofs.com/v1/wEjlTZWTu0NupQUfv5xXswaIkOJpm015FWHwShQxid
5WkxZO4TXcopTUYNpaUk1U6uSx_W1lGlmCdJKoTE0W290G7zuMtQ/BPMs/PODtl_QtyType.
> bpm> \ PO Detail Qty Type - Non Functional" file into
> "http://tech.groups.yahoo.com/group/vantage/files/BPMs/" folder.
> Let me know when you download the file, so I'll delete it. Don't want
> people think it's usable.
> mtonoyan@...
Behalf
> Of Jose Gomez
> Sent: Tuesday, May 31, 2011 10:03 AM
> Send us the bpm
> Sent from mobile
> On May 31, 2011 12:19 PM, "Mike Tonoyan" <mtonoyan@...
> <mailto:mtonoyan%40natelengr.com> > wrote:
> > After upgrading to 9.04.507 when modifying an existing PO, the "PO
> Entry
> > \ Lines \ Quantity/Cost" radio button is not defaulting to "Our
Qty".
> > When manually clicking on "Our Qty" it refreshes the Supplier qty,
> > otherwise it doesn't.
> > I created a Pre Processing BPM to offset this problem but for some
> > reason it's not working:
> > set the PODetail.QtyOption field of all unchanged rows to the "Our"
> > expression
> > mtonoyan@... <mailto:mtonoyan%40natelengr.com>
> > __________________________________________________________
> > Notice: This email transmission may contain confidential information
> and
> is intended only for the person(s) named. Any use, copying or
disclosure
> to/by any other person(s) is strictly prohibited. By accepting this
> information, recipients confirm that they understand and will comply
> with
> all applicable ITAR and EAR requirements.
and is
> intended only for the person(s) named. Any use, copying or disclosure
to/by
information,
> recipients confirm that they understand and will comply with all
applicable
______________________________________________________________________
Notice: This email transmission may contain confidential information and is intended only for the person(s) named. Any use, copying or disclosure to/by any other person(s) is strictly prohibited. By accepting this information, recipients confirm that they understand and will comply with all applicable ITAR and EAR requirements.
v8.03.4008B
I have customized the quote worksheet to apply a 2.5% adder upon checking a checkbox. The code works fine, but the worksheet does not recalculate unless I save, or change another field. I assume it is because it does not recognize the change event since it happens in code.
Trace logging indicates that RecalcWorksheet is called. How do I invoke this method on the form? I tried oTrans.RecalcWorksheet but got an error.
Thanks in advance.
Randy Weber
Hook on the main adapter bring in the reference to quote adapter then
connect call the fiction. I am ob the road so don't have the syntax but if
you hook onto an after adapter method it will give you an epibaseadapter
simple replace that with quoteafapter and call the recalc function then
notify your edv
Sent from mobile
On May 15, 2011 8:46 AM, "randyweb" <weber.randy@...> wrote:
> v8.03.4008B
> Thanks in advance.
> Randy Weber
Hi and thanks for the reply. Unfortunately, that is Greek to me. I don't know how to 'hook' to the main adapter nor the quote one. Could you be so kind as to paste some code describing this?
Randy
> notify your edv
> Sent from mobile
> > v8.03.4008B
> > Thanks in advance.
> > Randy Weber
QuoteAdapter quotAdp = (QuoteAdapter)csm.TransAdaptersHT["oTrans_adapter"];
That will get you the adapter. Once you've got it you can just call
the methods and such like any other object.
When you're done messing with everything call notify on the UI to make
everything show up.
qtDtlDV.Notify(new EpiNotifyArgs("QuoteForm", qdr.QuoteLine - 1,
EpiTransaction.NotifyType.Initialize));
That will notify the quote form. just replace 'qtDtlDV' with whatever
your dataview is called and 'qdr.quoteline -1' with the number for
whatever line you've updating.
> Randy
> if
> > notify your edv
> > Sent from mobile
> > > v8.03.4008B
> checking
> not
> > > Thanks in advance.
> > > Randy Weber
I think I am close here, but it's a bit different than what you wrote. I got this from the data tools:
Dim varQuoteAdapter As QuoteAdapter = New QuoteAdapter([UIForm])
varQuoteAdapter.BOConnect()
Dim [varName] As Boolean = [varAdapterName].RecalcWorksheet(quoteNum, quoteLine, qtyNum)
[varAdapterName].Dispose()
What goes in place of the [UIForm] portion?
Randy
> everything show up.
> > Randy
> > if
> > > notify your edv
> > > Sent from mobile
> > > On May 15, 2011 8:46 AM, "randyweb" <weber.randy@> wrote:
> > > > v8.03.4008B
> > checking
> > not
> > > > Thanks in advance.
> > > > Randy Weber
That would be the actual name of the form. In your case it would be
'QuotForm'. However, I would suggest using the oTrans method instead. It
saves you the trouble of having to look up the form name everytime. Also,
I've not tested the method your described and I'm pretty sure it will give
you a new adapter instead of using the existing Epicor adapter.
> quoteLine, qtyNum)
> Randy
> > everything show up.
> don't
> so
> > > Randy
> but
> > > if
> epibaseadapter
> then
> > > > notify your edv
> > > > Sent from mobile
> > > > > v8.03.4008B
> > > checking
> recalculate
> does
> > > not
> invoke
> error.
> > > > > Thanks in advance.
> > > > > Randy Weber
The name of your form, for example
QuoteEntryForm or SalesOrderEntryForm
In customization mode look at the top most level on the tree (left of
screen) that's what you put there.
See image http://www.josecgomez.com/files/OrderForm.png
However that code will give you a new instance of the adapter and not the
current adapter, to use the current adapter use the code provided by
John(Waffqle) before.
*Jose C Gomez*
Software Engineer
E: jose@...
> quoteLine, qtyNum)
> Randy
> > everything show up.
> don't
> so
> > > Randy
> but
> > > if
> epibaseadapter
> then
> > > > notify your edv
> > > > Sent from mobile
> > > > > v8.03.4008B
> > > checking
> recalculate
> does
> > > not
> invoke
> error.
> > > > > Thanks in advance.
> > > > > Randy Weber
This is still giving me fits. FYI - it's v8.03.408b
This line gives me Expected End of statement
Dim quotAdp = (QuoteAdapter)csm.TransAdaptersHT("oTrans_adapter")
As does this
Dim quotAdp = (QuoteAdapter)csm.TransAdaptersHT["oTrans_adapter"]
You are putting semi-colon at end of lines. Does not work for me. Are we using a different language?
Randy Weber
> *Jose C Gomez*
> Software Engineer
> E: jose@...
> > quoteLine, qtyNum)
> > Randy
> > > everything show up.
> > don't
> > so
> > > > Randy
> > but
> > > > if
> > epibaseadapter
> > then
> > > > > notify your edv
> > > > > Sent from mobile
> > > > > > v8.03.4008B
> > > > checking
> > recalculate
> > does
> > > > not
> > invoke
> > error.
> > > > > > Thanks in advance.
> > > > > > Randy Weber
It looks like you're using VB.
Jose and I write in C#, although the syntax will be a bit different if you
wanna do it in VB you need pretty much the same code.
> As does this
> Randy Weber
> > *Jose C Gomez*
> > Software Engineer
> > E: jose@...
> I
> > > quoteLine, qtyNum)
> > > Randy
> make
> > > > everything show up.
> > > don't
> be
> > > so
> > > > > Randy
> then
> syntax
> > > but
> > > > > if
> > > epibaseadapter
> function
> > > then
> > > > > > notify your edv
> > > > > > Sent from mobile
> > > > > > > v8.03.4008B
> upon
> > > > > checking
> > > recalculate
> > > does
> > > > > not
> I
> > > invoke
> an
> > > error.
> > > > > > > Thanks in advance.
> > > > > > > Randy Weber
You can give this a shot if you'd like
http://www.developerfusion.com/tools/convert/csharp-to-vb/
It should give you proper VB code
*Jose C Gomez*
*Software Engineer*
CHECK OUT MY NEW BLOG <http://www.usdoingstuff.com> OR CONTACT ME DIRECTLY*
E: jose@...
> > As does this
> > Randy Weber
> the
> > > *Jose C Gomez*
> > > Software Engineer
> > > E: jose@...
> wrote.
> > I
> > > > quoteLine, qtyNum)
> > > > Randy
> > make
> > > > > everything show up.
> whatever
> I
> > > > don't
> you
> > be
> > > > so
> > > > > > Randy
> adapter
> > then
> > syntax
> > > > but
> > > > > > if
> > > > epibaseadapter
> > function
> > > > then
> > > > > > > notify your edv
> > > > > > > Sent from mobile
> > > > > > > > v8.03.4008B
> > upon
> > > > > > checking
> > > > recalculate
> it
> > > > does
> > > > > > not
> do
> > I
> > > > invoke
> > an
> > > > error.
> > > > > > > > Thanks in advance.
> > > > > > > > Randy Weber
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
After upgrading to 9.04.507 when modifying an existing PO, the "PO Entry
\ Lines \ Quantity/Cost" radio button is not defaulting to "Our Qty".
expression
mtonoyan@...
Send us the bpm
Sent from mobile
> expression
> mtonoyan@...
Jose,
mtonoyan@...
Of Jose Gomez
Send us the bpm
Sent from mobile
Entry
> expression
and
with
no parenthesis.
*Jose C Gomez*
Software Engineer
E: jose@...
On Tue, May 31, 2011 at 4:39 PM, Mike Tonoyan <mtonoyan@...>wrote:
> Jose,
> mtonoyan@...
> Of Jose Gomez
> Send us the bpm
> Sent from mobile
> Entry
> > expression
> and
> with
