BPM To stop part being added to Quote if QuoteDtl.SellingExpectedUM to set to "NFS"
Hello,
I am trying to get a BPM working the way I want.
I created a UOM for parts where you can mark as NFS and added to a test part.
I then created a BPM at Erp.BO.Quote.Update that checks if the field SellingExpectedUM is set to NFS.
Then it goes to a Raise Exception marked as ‘Terminate on Error’.
When I add the part to a quote, the exception pops up but the part still populates the line. It does stop me from saving the quote though.
What I am trying to do is stop it from even populating the line section.
Where did I go wrong?
OK,
I am told I need to beusing the ChangePartNum instead of update if I want to stop the fields from being set anyways. He said to use Pre-processing to stop it.
What I am unsure of is how do I get the value it is going to be set as instead of the value it currently is.
When I do a message with the field in it, it shows ‘EA’ instead of what it will be ‘NFS’.
Any ideas? I can really use the help.
