BPMs After Backup and Restore 8.03.409C
There is a program in epicor to regenerate all enabled BPM.
You have to do it anytime you change a BPM and then restore you db.
On 2013-04-18 7:35 PM, "laraines422" <laraines422@...> wrote:
> Could it be an issue with the PROPATH that you have setup for your Test
> system?
> --- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> > Bpm code is generated into a .p file at startup or on enable.
> > It is possible that the .p is not being generated when you restore the
> db.
> > On Apr 18, 2013 5:50 PM, "adam.whipp" <adam.whipp@...>
> > wrote:
> > > We are on 8.03.409C. I've noticed if I take our "live backup" that runs
> > > every night and restore it to our test server, it seems the BPMs will
> not
> > > function unless I go into each one, uncheck the "enabled" box and then
> > > recheck it. Is this normal behavior after doing a restore from a backup
> > > file? It seems very odd to me.
> > > Thanks,
> > > Adam Whipp
> > > National Tube Form
We are on 8.03.409C. I've noticed if I take our "live backup" that runs every night and restore it to our test server, it seems the BPMs will not function unless I go into each one, uncheck the "enabled" box and then recheck it. Is this normal behavior after doing a restore from a backup file? It seems very odd to me.
Adam Whipp
National Tube Form
It is possible that the .p is not being generated when you restore the db.
> Thanks,
> Adam Whipp
> National Tube Form
Could it be an issue with the PROPATH that you have setup for your Test system?
> > Thanks,
> > Adam Whipp
> > National Tube Form
