BPMs not firing
We figured out the problem, of course it was associated with being the last
day of the year and a BPM that had bad date arithmetic.
*Tanya Denison* | IT Manager | NRS, Inc.
*2009 S. Main Street, Moscow, ID 83843*
*tdenison@... *|* www.nrsweb.com*
*c: 208.301.0599* | *p: 208.883.7834 Ext 277 *|* f: 208.882.1744*
*From:* vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] *On Behalf
Of *tanya_denison
*Sent:* Monday, December 31, 2012 4:03 PM
*To:* vantage@yahoogroups.com
*Subject:* [Vantage] BPMs not firing
I am completely stumped by this one. I have a set of simple BPMs on
SalesOrder.GetNewOrdHed. All they do is set a default value in
Post-Processing.
Today, out of the blue, they suddenly stopped working. All the directives
under that method. From what I can tell, only that method is affected.
I had not made any changes to BPMs or any code actually in over a week.
I checked that the directives are enabled and the code looks correct. I
disabled, saved, then enabled and saved again.
I also mass regenerated all methods, same results.
Any ideas?
Tanya Denison | IT Manager | NRS, Inc.
tdenison@... | www.nrsweb.com
c: 208.301.0599 | p: 208.883.7834 Ext 277 | f: 208.882.1744
I am completely stumped by this one. I have a set of simple BPMs on SalesOrder.GetNewOrdHed. All they do is set a default value in Post-Processing.
Today, out of the blue, they suddenly stopped working. All the directives under that method. From what I can tell, only that method is affected.
I checked that the directives are enabled and the code looks correct. I disabled, saved, then enabled and saved again.
Any ideas?
