Bring up my Dashboards at login
In dashboard query properties , set "Auto Refresh On load" to TRUE
deploy dashboard make sure you tick "Smart Client", "Add Menu Tab", and other one..
create a menu, and launch the dashboard as dashboard-assembly. (note down menu id)
goto utilites > process calling maintenance > create a new process...set called process ref and called from value anything u would like and give the right menu id which you noted while creating menu for dashboard.
i randomly found this way..if its not the right way, please guide me doing this right way...
cheers!
--- In vantage@yahoogroups.com, <vantage@yahoogroups.com> wrote:
Hi Manasa,
Right click on Favorites Group and select Autoload this Group.
Regards,
Arul
To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
Sent: Tuesday, 10 September 2013 3:14 AM
Subject: RE: [Vantage] Bring up my Dashboards at login
<div id="ygrps-yiv-812044646yiv0799243449ygrp-text">
  <div>
That was what I was looking for…how do I autoload the group?
M
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Winter, Patrick
Sent: Monday, September 09, 2013 10:56 AM
Put them in a favorites group and autoload the group.
Patrick Winter
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Manasa Reddy
Sent: Monday, September 09, 2013 10:50
Subject: [Vantage] Bring up my Dashboards at login
Ok…I did forget how to do this….someone please remind me.
When I login to Epicor, I want certain dashboards to automatically launch.  How to do this again?
We are on 9.05.607B….thanks in advance!
Manasa
</div>
Manasa
As tabs in your main epicor screen?
On the main window,
Options>Preferences>Tabs
Click New and set it to the dashboard you want to use from the drop down combo.
Patrick Winter
Manasa
M
Patrick Winter
Manasa
Right click on Group Name and select
Patrick Winter
Sent: Monday, September 09, 2013 12:15
To: 'vantage@yahoogroups.com'
M
Patrick Winter
Manasa
Hi Manasa,
Regards,
Arul
<div id="ygrps-yiv-755949044yiv0799243449ygrp-text">
  <div>
M
Patrick Winter
Manasa
</div>
