Broker rejects connection ODBC error - what does this mean - I c
Technically, you are better off to do it through Promon since you will know which one you are killing but you can still do it through task manager or the command line.  It is just a bit more of a blunt instrument to do so.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
On Mar 6, 2015, at 8:02 AM, Mike Abell mabell@... [vantage] <vantage@yahoogroups.com> wrote:
Michael, thanks SO much for the explanation.  So it’s safe to purge those SQLServer.exe processes then?  I mean, I did it and it fixed the connection issue but I didn’t “like” doing it.  But if it’s safe, I’ll remember it for next time…
Mike..
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
Sent: Friday, March 06, 2015 8:50 AM
To: vantage@yahoogroups.com
Subject: Re: [Vantage] Broker rejects connection ODBC error - what does this mean - I cannot run Crystal reports....
External Crystal Reports absolutely can cause this problem.  Any process that utilizes ODBC (Crystal, Excel, Access, etc) will spawn an SQL broker process.  Each of those SQL brokers is configured for a finite number of client connections in the ODBC configuration section of PET or Open Edge Explorer.  Additionally, the ODBC broker configuration contains a setting for the maximum number of server processes that can be spawned.  Multiplying the maximum number of client connections per server by the maximum number of servers will give you the total number of possible connections.
Technically, all ODBC processes are external to Progress/OE since the application typically connects to the DB through the 4GL broker and port.  It is fairly common for those external ODBC processes to leave a connection open and occupy a connection well after the process has ended so, sometimes, it is necessary to purge the brokers and let Progress spawn new ones.  You can end the broker process, as you have, through task manager and/or the command line or you can use Promon.  Additionally, Promon can be used to display how many connections each broker has open so that you can identify the brokers that need to be cycled.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
On Mar 4, 2015, at 12:51 PM, Mike Abell mabell@... [vantage] <vantage@yahoogroups.com> wrote:
We do not have but a few people who have ODBC access, I’m by far the person that uses it the most.  I ended up blowing away 4 out of the 8 sqlservr.exe processes on the server and that seemed to fix it.  Are those processes not supposed to free their memory and processes when they aren’t being used.  I had “8” processes going and that is the number configured in the progress DB properties but I know for SURE I’m the only one that does anything ODBC related daily so I’m not sure why it was pegged out.  Does external Crystal Reports cause this problem???
Mike Abell
Information Technology Manager
Flexial - BOA Group - Cookeville, Tennessee
Office:   931.432.8408
Mobile:  615.418.3055
email:  MAbell@...
Sent: Wednesday, March 04, 2015 2:31 PM
Mike,
Depending upon the simultaneous number of ODBC users, you may be running out of available broker processes to handle the request.  You can check the number of available servers on the DB’s ODBC configuration and you can compare that to the current activity from the Promon-R&D-status-servers display.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
This email, and any attachments thereto, is intended only for use by the addressee(s) named herein and may contain legally privileged and/or confidential information.  If you are not the intended recipient of this email, you are hereby notified that any dissemination, distribution or copying of this email, and any attachments thereto, is strictly prohibited.  If you have received this email in error, please immediately notify me by telephone and permanently delete the original and any copy of any email and any printout thereof.
On Mar 4, 2015, at 9:36 AM, Mike Abell mabell@... [vantage] <vantage@yahoogroups.com> wrote:
I just received this error trying to run a Vantage 8.03 custom Crystal report using ODBC.  What do I need to reset on the server?
Mike Abell
email:  MAbell@...
Mike Abell
email:  MAbell@...
Mike,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Mike Abell
email:  MAbell@...
Mike Abell
email:  MAbell@...
Mike,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Mike Abell
email:  MAbell@...
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Mike Abell
email:  MAbell@...
Mike,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Mike Abell
email:  MAbell@...
Mike..
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Mike Abell
email:  MAbell@...
Mike,
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Mike Abell
email:  MAbell@...
