NEVER modify and save the base with changes.
Save your mods under a customization name and then activiate the customization via menu maintenance.
--- On Tue, 4/29/08, Tony Hughes <thughes281@...> wrote:
Subject: [Vantage] Bug in "Select Customization and Translation" or am I doing it wrong?
Date: Tuesday, April 29, 2008, 2:29 PM
How do I make the customizations for all?
I'm using the "Epicor Tools User Guide"
we're have 8.03.404a
I put Vantage in Developer Mode (my logon has Security Manager)
open Sales Order Entry
I check "Base Only"
(book says that 'Available Layers " should now be disabled, but it is not)
Follow the basic sample in the book about discount being over 5% turning the DiscountPercent background red.
Using the rule wizards, I create the rule as per the books instructions
Save it, name it, and close the Sales Order Entry screen
Remove Developer Mode
Test the rule, and it doesn't work.
Put Vantage back ni Developer Mode, open Sales Order Entry.
My modification is not listed under Base as the picture in the book shows, but my modification is under Customizations.
So, if it's A. supposed to be under Customizations, how do I make it default for all users?
or B. How is it correctly under Base so that it is default for all users?
Thank you!
____________ _________ _________ _________ _________ _________ _
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
____________________________________________________________________________________
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
