Thank you, much appreciated!
--- In vantage@yahoogroups.com, Greg Payne <gpayne@...> wrote:
> 607: System maintenance > Utilities > Customization Maintenance. Search for customization and then export it. It will default to a location under the server and version you are running. Change to a common easier to find location.
> 702: Same program as above, click import Customization. Find the above file. After import click Verify Customization. If all is good, it will show status passed and valid for 702.
> If not then look at the errors or warnings.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of clederer@...
> Sent: Friday, June 21, 2013 4:32 PM
> To: vantage@yahoogroups.com
> Subject: [BULK] [Vantage] How to Copy a Customization From 1 Database to another
> Importance: Low
> In Epicor 9607a, I created a customization which was on the "part maintenance" layer not the base layer. It's a drop down box and I'm trying to copy it to Epicor 702. Not sure how to go about copying the customization from 1 database to the other
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
