Business Activity Alert syntax problem - Help
In addition to the comments below, we also discovered you can send
the email to multiple addresses by seperating with a comma. You
used the format "user1@..., user2@..."
Just thought we would post it as "historical" data.
Aaron Hoyt
Hittite Microwave
--- In vantage@yahoogroups.com, aaronhoyt@v... wrote:
> John and others interested,
> Cliff and I took the original thread offline. These is the
results
> that I have managed to make work in our testing environment. I
> thought others might find it of use, so I decided to publish the
> results. Forgive the length of the message please.
> (for auto email upon the creation of an order for a "credit hold"
> customer)
> CreditHO.p
> {ud/GlbAlert.i &tablename = "OrderHed" }
> DEFINE VARIABLE NewEmailBofy AS CHARACTER NO-UNDO.
> /*new email body*/
> IF OrderHed.OpenOrder = TRUE
> THEN DO:
> FIND Customer WHERE (Customer.Company = OrderHed.Company) AND
> (Customer.Custnum = OrderHed.Custnum)
> NO-LOCK.
> IF Customer.CreditHold = TRUE
> THEN DO:
> ASSIGN Email-To = "hoyt@h..."
> Email-Subject = "Credit Hold Order"
> Email-Text = "Sales order "
> + string(OrderHed.Ordernum)
> + " has been created for "
> + string(Customer.name)
> + " and they are on credit hold.".
> END.
> ELSE DO:
> Return "Cancel Send":U.
> END.
> END.
> ELSE DO:
> END.
> (for automatic email on the use of the override function from the
AR
> module for a specific order)
> CreditOR.P
> /*new email body*/
> IF OrderHed.CreditOverride = TRUE
> THEN DO:
> NO-LOCK.
> Email-Subject = "Credit Override"
> END.
> ELSE DO:
> END.
> If anyone uses either of these codes, please remove my address
from
> the "Email-To" field. I don't mind it being used by those with
> questions, but I really don't want to know every time you create
> orders for credit hold customers.
> Feel free to customize this code for your purpose. As for the
> GlbAlert.i include program, please call your Epicor rep and ask
for
> a copy.
> Good luck to all.
> Aaron Hoyt
> Hittite Microwave Corporation
Our system (Vantage 6 .515) is set up to Warn when Credit Hold is
overridden. I need to set up a Business Activity Manager Alert to tell the
CFO when this is done. I set the alert up on OrderHed.Creditoverride field.
This will send an alert for every order created as the logical meets both
true and false. My aim is to only send an email when it is true.
I wrote the following in an attempt achieve this.
{ud/GlbAlert.i &tablename = "orderhed" }
/*new email body*/
IF orderhed.creditoverride = TRUE
THEN DO:
ASSIGN Email-Subject = "Credit Override"
ASSIGN Email-Text = "Sales order created for customer on credit hold.".
END
ELSE DO:
Return Error.
END.
This returns the following error codes when creating a sales order
and then shuts down Vantage.
<<...OLE_Obj...>>
<<...OLE_Obj...>>
line 9 is the ELSE DO:
LINE 10 IS Return error.
Where have I gone wrong with the logic or syntax ?? Any help would
be greatly appreciated.
Cliff Drumeller
IT Manager
Mass Precision Sheetmetal
408 954 0200
> field. This will send an alert for every order created as the logical
> meets both true and false. My aim is to only send an email when it is
> true.
> /*new email body*/
> THEN DO:
> END
> ELSE DO:
> Return Error.
> END.
> Credit override.p Could not understand line 9. (198) line 9 is the
> ELSE DO:
> Credit override.p Line 10. Colon followed by white spaces terminates a
> statement LINE 10 IS Return error.
> Cliff Drumeller
> IT Manager
> 408 954 0200
Cliff,
If this is the actual text of the proram, you might want to look at
adding a . after the end statement before the ELSE DO:. I don't
know if that is the problem or not, but I think it might have been
overlooked.
Good luck,
Aaron Hoyt
Hold is
tell the
meets both
> /*new email body*/
> THEN DO:
hold.".
> END
> ELSE DO:
> Return Error.
> END.
order
> <<...OLE_Obj...>>
> <<...OLE_Obj...>>
would
> Cliff Drumeller
> IT Manager
> 408 954 0200
Cliff,
You also might want to add something other than a return error,
like...
RETURN "CANCEL SEND":U.
That should eliminate the email if your field is not True.
Hope this helps,
Aaron Hoyt
--- In vantage@yahoogroups.com, "aaronhoytwork" <aaronhoyt@v...>
wrote:
> Cliff,
at
> overlooked.
> Good luck,
> Aaron Hoyt
> Hold is
to
> tell the
> meets both
> > /*new email body*/
> > THEN DO:
> hold.".
> > END
> > ELSE DO:
> > Return Error.
> > END.
> order
> > <<...OLE_Obj...>>
> > <<...OLE_Obj...>>
> would
> > Cliff Drumeller
> > IT Manager
> > 408 954 0200
Aaron,
I would like to be able to use Global Alerts like Cliff.
I don't have Provision. Can I use a text editor to make
Conditional statements so the emails that go out have
A little more intelligence to them. Is Cliff's example a good one to
use? Do you have an example that could
Be used as a template?
John Mansfield
General Sheet Metal
Sent: Monday, December 15, 2003 3:59 PM
Subject: [Vantage] Re: Business Activity Alert syntax problem - Help
Cliff,
like...
Hope this helps,
Aaron Hoyt
wrote:
> Cliff,
at
> overlooked.
> Good luck,
> Aaron Hoyt
> Hold is
to
> tell the
> meets both
> > /*new email body*/
> > THEN DO:
> hold.".
> > END
> > ELSE DO:
> > Return Error.
> > END.
> order
> > <<...OLE_Obj...>>
> > <<...OLE_Obj...>>
> would
> > Cliff Drumeller
> > IT Manager
> > 408 954 0200
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cnkinbp/M=267637.4116730.5333196.1261774/D=eg
roupweb/S=1705007183:HM/EXP=1071608352/A=1853618/R=0/*http:/www.netflix.
com/Default?mqso=60178338&partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egrou
pmail/S=:HM/A=1853618/rand=731959221>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
John,
I am betting there are more qualified people on this list to answer
this question, but I will give a shot.
1. There is no need for Provision. I don't have it either. You
can either use the Procedure Editor built into Progess, or your
favorite Plain text editor to write a sample .P file.
2. From the syntax Cliff used, I assume he is learning from the
same source that I am. Epicor Rep (Jeff for me) sent me a sample to
use to build into an automated Email Notification System for our
customers (shipping notification). I am still working on formatting
that, but the source is very similar. If Cliff did not use this
source, I apologize Cliff.
3. This can balloon into a ton of projects. As you discover what
you can do with .vbp, .P, .I, and .W files with just a text editor,
you will find a new horizon. Especially when combined with the new
freedom Vantage has in 6.0 with its "Customization". The
possibilities are endless.
You do have some programming to learn, but so far I have done little
reading and bunches of code modification. Good place to start
reading is in Help files from the respective tools (VBForms),
(Procedure Editor) etc.
Good luck.
Aaron Hoyt
--- In vantage@yahoogroups.com, "John Mansfield" <johnm@g...> wrote:
> Aaron,
to
> Thanks,
> John Mansfield
> General Sheet Metal
> From: aaronhoytwork [mailto:aaronhoyt@v...]
Help
> Cliff,
> like...
> Hope this helps,
> Aaron Hoyt
> wrote:
> > Cliff,
> at
been
> > overlooked.
> > Good luck,
> > Aaron Hoyt
Credit
> > Hold is
> to
> > tell the
> > meets both
true.
> > > /*new email body*/
> > > THEN DO:
credit
> > hold.".
> > > END
> > > ELSE DO:
> > > Return Error.
> > > END.
sales
> > order
> > > <<...OLE_Obj...>>
> > > <<...OLE_Obj...>>
help
> > would
> > > Cliff Drumeller
> > > IT Manager
> > > 408 954 0200
Cliff and I took the original thread offline. These is the results
customer)
CreditHO.p
/*new email body*/
THEN DO:
NO-LOCK.
THEN DO:
ASSIGN Email-To = "hoyt@..."
END.
ELSE DO:
END.
END.
ELSE DO:
END.
(for automatic email on the use of the override function from the AR
CreditOR.P
/*new email body*/
THEN DO:
NO-LOCK.
END.
ELSE DO:
END.
If anyone uses either of these codes, please remove my address from
GlbAlert.i include program, please call your Epicor rep and ask for
a copy.
Good luck to all.
Aaron Hoyt
