Business Activity Manager
I actually customized the form to hold a conversion date so that I can
run a report that tells me the customers that were created within a
given time frame. I know that the table holds a creation date but I need
to know when the record was converted from Prospect to Customer
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of charles06072006
Sent: Wednesday, January 23, 2008 8:30 AM
Subject: [Vantage] Re: Business Activity Manager
I submitted that issue with alerts almost a year ago to Epicor. I
told them at the time that alerts were absolutely useless the way
they were. I suppose they still are. They gave no inidication as to
when or if this issue would be fixed.
I agree with Stephen, use BPM instead and forget about alerts.
"Stephen Edginton" <stephene@...>
wrote:
> Use a BPM instead
> Method directive Customer.update
> Then send an alert from this.
Behalf
> Of kam4085
> Sent: Monday, January 21, 2008 4:03 PM
> Subject: [Vantage] Business Activity Manager
> I am trying to set up an alert that will show when a customer's
status
> has changed. I want it to include the customer name and the status
> change whenever the record has been added or the status has been
> updated. The problem that I am running into is that when entering a
new
> record that goes directly to a status of customer the only alert
that I
> get is that a new record has been added with no referance to what
the
> record is. When I save the record and then change the status I get
an
> alert telling me that the status has been updated but I still don't
> know which record has been updated. The only way I can get the name
> included in the alert is to change the name of an existing customer
> record. WHat I want is the name of the customer and the showing of
a
> status change for both new records and the updating of existing
> records. Does anyone out there know how to do this? Without any key
> information (name,custid) the process seems useless.
> Thanks
> Kersten
I am trying to set up an alert that will show when a customer's status
updated. The problem that I am running into is that when entering a new
record that goes directly to a status of customer the only alert that I
get is that a new record has been added with no referance to what the
record is. When I save the record and then change the status I get an
record. WHat I want is the name of the customer and the showing of a
Kersten
Use a BPM instead
Of kam4085
Kersten
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
> Use a BPM instead
Behalf
> Of kam4085
status
new
that I
the
an
a
> Thanks
> Kersten
