Business Activity Query language
I asked a programmer friend of mine who did some programming for v8.
She said it had been a while since she had worked with the BAQ bbut
her recollection was it was Progress. - Monte
--- In vantage@yahoogroups.com, Judy Perry <jrperry49@...> wrote:
> Hi Debra,
> A couple things to look at:
> 1. You have to make sure that you have selected the correct
table on the filter screen in the BAQ where you enter the filtering
criteria
> 2. If you are using a date range you should apply the
parantheses around the filter statements
> 3. Review what the filter looks like in the Query Phrase to make
sure what you are expecting is being produced before doing the
Analyze > Test.
> Call Tech Support if you are still having any issue.
> Regards,
> Judy Perry
> "debra.putnam" <dputnam@...> wrote:
> Thanks Monte, but I know how to link two tables using the
second
> screen of the Phrase Builder, but when I try and link multiple
> tables and I have filters on one of the child tables, it doesn't
> filter properly. It runs the report but I have never been able to
> see it because it has too many records. I am thinking in the
secound
> screen that I could modify the language (if I knew what it was)
then
> I could join multiple tables and have them filter properly.
> Debra
> --- In vantage@yahoogroups.com, "Monte Tomerlin" <monte@> wrote:
> > You link table in the BAQ in the second screen of the Phrase
> Builder.
> > It auto-links for you but you can modify the linkage if needed -
> Monte
> > Tomerlin
> > --- In vantage@yahoogroups.com, "debra.putnam" <dputnam@> wrote:
> > > Does anyone know how to join multiple tables using the Business
> > > Activity Query? If I use the Query wizard it doesn't seem to
> work.
> > > I want to join tables like Company.Company, OrderHed.Company,
> > > ShipHead.Company, ProdGrup.Company, OrderRel.Company with
> filters
> > > using OrderRel.ReqDate and ProdGrup.Description.
> > > After using the Query wizard, and I Analyze the Statement it
> says it
> > > is ok, but when I run it, it is not recognizing the filters and
> pulls
> > > in thousands of records. I am thinking that I need to know the
> > correct
> > > language to 'inner join' the tables. This is not in the Vantage
> help
> > > menu. Can anyone point me in the right direction?
> > > Debra Putnam
> > > Damar Machine Company
> Never miss a thing. Make Yahoo your homepage.
Activity Query? If I use the Query wizard it doesn't seem to work.
ShipHead.Company, ProdGrup.Company, OrderRel.Company with filters
After using the Query wizard, and I Analyze the Statement it says it
is ok, but when I run it, it is not recognizing the filters and pulls
in thousands of records. I am thinking that I need to know the correct
language to 'inner join' the tables. This is not in the Vantage help
Debra Putnam
You link table in the BAQ in the second screen of the Phrase Builder.
It auto-links for you but you can modify the linkage if needed - Monte
Tomerlin
correct
> Debra Putnam
Thanks Monte, but I know how to link two tables using the second
see it because it has too many records. I am thinking in the secound
screen that I could modify the language (if I knew what it was) then
Debra
Builder.
Monte
> Tomerlin
work.
filters
says it
pulls
> correct
help
> > Debra Putnam
Hi Debra,
1. You have to make sure that you have selected the correct table on the filter screen in the BAQ where you enter the filtering criteria
2. If you are using a date range you should apply the parantheses around the filter statements
3. Review what the filter looks like in the Query Phrase to make sure what you are expecting is being produced before doing the Analyze > Test.
Regards,
Judy Perry
Debra
Builder.
Monte
> Tomerlin
work.
filters
says it
pulls
> correct
help
> > Debra Putnam
