Yes. That is normal. You actually configure how often you want your
Global Alerts Email Task to trigger at System Management - Utilities -
Global Alerts/Email Server Process... When you submit the process it
asks for the value for the "Continuous Process Delay". Ours is set to 1
minute. Even though your "Start Up Task Schedule" is set to "start up"
on the System Agent your Global Email Alerts will still run every minute
or however long you have them set. Does this make sense?
Blake Clemens
DMC
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Charlie Wilson
Sent: Monday, March 09, 2009 3:43 PM
To:
Subject: RE: [Vantage] Re: Global Alerts are not sending
Sys agent in vantage that global alerts email task is set to only run on
startup.
~Charlie
_____
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Blake Clemens
Sent: Monday, March 09, 2009 3:41 PM
To:
Do you mean the Task Agent Appserver in your progress explorer tool or
your system agent in Vantage?
Blake Clemens
DMC
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Monday, March 09, 2009 3:38 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
I got it fixed the agent task was not restarting. because it is only
sched
to run on startup. Is this the way it should be?
~Charlie
_____
Behalf Of
Blake Clemens
Sent: Monday, March 09, 2009 3:30 PM
Ok, have you done all of this?
Blake Clemens
DMC
Behalf
Of Jennifer
Sent: Monday, March 09, 2009 3:23 PM
Subject: [Vantage] Re: Global Alerts are not sending
Here are the instructions for setting up Global Alerts. Verify that all
of these components are setup correctly. Make sure that your scheduled
startup is enabled and that your mail server allows relaying.
1. From the main menu, select System Management->Company
Configuration->Company->Email.
In the Email Link Port field, enter an unused port number. This port
will be used by the product when sending a global alert with an
attachment. When the user receiving the alert clicks on the attachment,
the product will be "listening" on this port to retrieve the correct
data in a tracker related to the alert if the user has a session of the
product open when the alert's attachment is double-clicked.
In the Global Alert Email Address From and Label fields, enter the email
address and label enter the default email address and label that global
alerts will be created with whenever an alert is sent.
In the SMTP section of the screen, enter your mail server and its
related port number.
2. Make sure you have a startup process to schedule your global alerts.
To do this, go to your System Agent (System Management -> Utilities ->
System Agent), do a search and open up your System Agent. Expand the
tree on the left until you get to schedules, if you have a start up
schedule already skip the next paragraph. If not, do a File-> New
Schedule, leave the schedule number blank, give it a Description of
Startup, make sure the Enabled checkbox is checked, and make sure
schedule type is Start Up.
3. Next, go to System Management -> Utilities -> Global Alerts Email
Server Process. Select the newly created startup schedule from the pull
down menu, check continuous and reoccurring, press submit.
4. You have now attached the process to a startup schedule. This will
cause the global alerts process to run as long as the ProcessServer and
TaskAgent are running. To make this active, restart your ProcessServer
and TaskAgent for the database you are in from the Progress Explorer
Tool. This will not kick people out of Vantage and can be done at any
time. Do not stop the main (top) appserver though; that will kick people
out of Vantage.
5. You will now see a GlobalAlertsEmail.log file in your mfgwrk80
directory. You can check this log file to see that emails are sending
and if they are not what possible issues you could be encountering. (The
error messages are outputted here).
Possible errors:
SMTP code 0: Either the SMTP server is setup wrong in your company
configuration (System Management -> Company -> email tab) or there is
something blocking communication. For example, many virus solutions will
block traffic on port 25, assuming that it is spam. To check your smtp
server, you can do a "telnet smtpservername 25" from a command prompt.
This should connect you to the SMTP server, type "helo" and press enter
and see if you get a response.
550 Relaying not allowed: This is a very common issue. Since Vantage
sends out the mail without any authentication most mail servers will not
allow the mail to be sent. You have to tell your mail server to allow
relaying. Most mail servers will let you allow relaying from a
particular host; in this case make it your Vantage server.
Jennifer Mesiano
Walton Signage
IT Manager
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
<mailto:vantage%40yahoogroups.com> ,
"Blake Clemens" <blake.clemens@...> wrote:
> Check your System Agent...System Management-Utilities-System Agent.
> Your global alerts should be listed underneath schedules. Make sure
the
> schedule that you attached your global alerts to is configured
> correctly. In your Progress Explorer Tool restart your Process Server
> and Task Agent appservers. Check and see if the global alerts are
> working now.
> Thanks,
> Blake Clemens
> DMC
Behalf
> Of Steve_E
> Sent: Monday, March 09, 2009 8:27 AM
> Subject: RE: [Vantage] Global Alerts are not sending
> Charle,
> Look in the system monitor and see if the global alert is stuck in the
> active tasks. If there is delete it and see if it runs correct on the
> next
> cycle time. (This is if the process is set to run every xx minutes)
> Steve
> -----Original Message-----
> From: Charlie Wilson [mailto:foamdesigncsw@...
> <mailto:foamdesigncsw%40yahoo.com> ]
> Sent: March 09, 2009 7:21 AM
> Subject: [Vantage] Global Alerts are not sending
> All,
> Our production server will not send out global alerts what would cause
> this
> to happen.
> I assume a reboot might fix it but the problem is I really can't
reboot
> the
> server right now.
> ~Charlie
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.9/1991 - Release Date:
03/09/09
07:14:00
03/09/09
07:14:00
