So nobody has a solution to trigger a refresh (or call the retrieve button ) ? Seems there is an example in the ICE manual, but I can't make it work...
--- In vantage@yahoogroups.com, "hexadecimalman" <christian.duguay@...> wrote:
> Hi Jose,
> Yes I know that, but this is not what I'm looking for. The Dashboard is Embedded in the quote entry and display summaries for pricing and discounts (the standard summary sheet is not accurate for us). So I need it to refresh whenever price, qty or discount values changes.
> --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > If its an embeded dashboard while you are embeding the dashboard you can
> > subscribe it to the field and then when that field changes the dashboard
> > will auto refresh.
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > <http://www.usdoingstuff.com>
> > *Quis custodiet ipsos custodes?*
> > On Fri, May 31, 2013 at 9:02 AM, hexadecimalman <
> > christian.duguay@> wrote:
> > > Hi All,
> > > Would like to know how to programmatically trigger a refresh on an
> > > embedded dashboard following a field change event in the UI.
> > > Thanks
> > > Christian
