C# customization help - 9.05.607
I had tried that MessageBox thing, but I put it in the wrong place before. This time, I have it before I set the double variable. It did help!
But, it still failed to run. So I changed the variable declaration to a float, and then it worked fine.
Thanks for the guidance!
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> You could try the old fashioned messagebox for this
> MessageBox.Show(args1.ToSTring()... etc)
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Wed, Dec 19, 2012 at 10:48 AM, mattcald_73 <matt@...> wrote:
> > Thanks for the tip, Jose!
> > Do you have a trick to see what is being passed to the custom code? What
> > data is in those RowRuleDelegateArgs(args.ARG1, args.ARG2, etc...)?
> > Trying a simple c# customization where the PO number gets highlighted if a
> > parts' pricing is <= 0.
> > CODE:
> > private bool
> > OrderDtlDocUnitPrice000_CustomRuleCondition(Epicor.Mfg.UI.ExtendedProps.RowRuleDelegateArgs
> > args)
> > bool result = false;
> > // ** RowRuleDelegateArgs Properties: args.Arg1, args.Arg2, args.Context,
> > args.Row
> > // ** put Row Rule condition evaluation logic here
> > double docPrice = System.Double.Parse(args.Arg1.ToString());
> > if (docPrice <= 0)
> > return true;
> > return result;
> > The test compiles fine, with no error. When I run it in Order entry, I get
> > "Input string was not in a correct format." message.
> > Can you give me a hint? :)
> > --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > > The Obejct Explorer is always in VB silly old thing that is. Simply
> > convert
> > > it Using one of the many online converters or see below (in this case)
> > > VB
> > > Dim OrderDtl2 As EpiDataView = this.oTrans.EpiDataViews("OrderDtl");
> > > C#
> > > EpiDataView OrderDtl2 = oTrans.EpiDataView["OrderDtl"];
> > > VB
> > > Dim docPrice As Decimal =
> > OrderDtl2.dataView(OrderDtl2.Row)("DocUnitPrice");
> > > C#
> > > Decimal docPrice = OrderDtl2.dataView[OrderDtl2.Row]["DocUnitPrice"];
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Fri, Dec 14, 2012 at 11:50 AM, mattcald_73 <matt@> wrote:
> > > > I am kind of new to the c# thing, but the code in the Object Explorer
> > > > looks like VB code. I haven't seen "DIM" in c# before.
> > > > I opened my customization with C# as my "Default Customization
> > Programming
> > > > Language", and the Script Editor has the C# radio button checked. This
> > is
> > > > what the Object Explorer tells me to use for DocUnitPrice in the
> > OrderDtl
> > > > table(variables named).
> > > > Can't seem to get the code above to do anything but give me errors:
> > > > --------compile errors------------
> > > > Error: CS1002 - line 72 (373) - ; expected
> > > > Error: CS1002 - line 73 (374) - ; expected
> > > > ** Compile Failed. **
> > > > Can one of you sharp c# guys give me a kick in the right direction?
> > > > --Matt
I am kind of new to the c# thing, but the code in the Object Explorer looks like VB code. I haven't seen "DIM" in c# before.
I opened my customization with C# as my "Default Customization Programming Language", and the Script Editor has the C# radio button checked. This is what the Object Explorer tells me to use for DocUnitPrice in the OrderDtl table(variables named).
Dim docPrice As Decimal = OrderDtl2.dataView(OrderDtl2.Row)("DocUnitPrice");
--Matt
The Obejct Explorer is always in VB silly old thing that is. Simply convert
VB
C#
VB
C#
*Jose C Gomez*
*Software Engineer*
E: jose@...
> --Matt
Do you have a trick to see what is being passed to the custom code? What data is in those RowRuleDelegateArgs(args.ARG1, args.ARG2, etc...)?
Trying a simple c# customization where the PO number gets highlighted if a parts' pricing is <= 0.
CODE:
private bool OrderDtlDocUnitPrice000_CustomRuleCondition(Epicor.Mfg.UI.ExtendedProps.RowRuleDelegateArgs args)
// ** RowRuleDelegateArgs Properties: args.Arg1, args.Arg2, args.Context, args.Row
if (docPrice <= 0)
return true;
return result;
The test compiles fine, with no error. When I run it in Order entry, I get "Input string was not in a correct format." message.
> VB
> C#
> VB
> C#
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > --Matt
*Jose C Gomez*
*Software Engineer*
E: jose@...
> CODE:
> private bool
> args)
> args.Row
> if (docPrice <= 0)
> return true;
> return result;
> convert
> > VB
> > C#
> > VB
> > C#
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> Programming
> is
> OrderDtl
> > > --Matt
Also Row Rules will do this for you with 0 code. They wll highlight fields
in an array of colors (Red, Green, Yellow)
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> CODE:
>> private bool
>> args)
>> args.Row
>> if (docPrice <= 0)
>> return true;
>> return result;
>> convert
>> > VB
>> > C#
>> > VB
>> > C#
>> > *Jose C Gomez*
>> > *Software Engineer*
>> > E: jose@...
>> Programming
>> This is
>> OrderDtl
>> > > --Matt
