I am trying to do a customization that checks for a radio button to be checked, if it is and the gl account first four digits fall into a range of 1300 - 1399 i want to display an error. I am currently stuck on trying to take the value that i am getting from the textbox and parse it to an int but only grab the first 4. Can someone provide some help or a path to do this easier?
My current code…
GLAccountNum = (EpiGLAccountEditor)csm.GetNativeControlReference("1f3edba8-bf41-4a96-8f08-5a72281ec54f");
RadioButtonValue = (EpiRadioButton)csm.GetNativeControlReference("7a2ae529-a68e-4bca-8517-cfd5ecb8f527");
MessageBox.Show (GLAccountNum.Text);
if (GLAccountNum.Text != null);
//GLAccountNumber = Convert.ToInt32(GLAccountNum.Text);
Int32.TryParse(GLAccountNum.Text, out GLAccountNumber);
MessageBox.Show (Convert.ToString(GLAccountNumber));
if (RadioButtonValue.Checked = true & (GLAccountNumber >= 1300 & GLAccountNumber < 1400));
MessageBox.Show ("Please update your number fool");
Below is the error i am receiving now. It does compile successfully.
Application Error
Exception caught in: mscorlib
Error Detail
Message: Index and length must refer to a location within the string.
Parameter name: length
Program: CommonLanguageRuntimeLibrary
Method: Substring
Client Stack Trace
at System.String.Substring(Int32 startIndex, Int32 length)
at Script.edvPODetail_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
at Ice.Lib.Framework.EpiViewNotification.Invoke(EpiDataView view, EpiNotifyArgs args)
at Ice.Lib.Framework.EpiDataView.OnEpiViewNotification(EpiNotifyArgs e)
at Ice.Lib.Framework.EpiDataView.Notify(EpiNotifyArgs args)
at Ice.Lib.Framework.EpiDataView.SetChildFilterAndNotifyChildViewWhenNoCurrentRow(EpiDataView childView, EpiNotifyArgs args)
at Ice.Lib.Framework.EpiDataView.SetChildFiltersAndNotifyChildViews(EpiNotifyArgs args, Boolean forceIt)
at Ice.Lib.Framework.EpiTransaction.NotifyAll()
at Ice.Lib.Framework.EpiBaseForm.setupUIElements()
Try assigning the substring to a separate string variable first, and then running the convert separately.
I’ve often found nested methods that work elsewhere will error out in Epicor. It’s usually in an if statement, but I’ve seen it in string manipulation too.
I took my code out and put yours in and it did not like the else statement so i removed that and added int GLAccountNumber; and this also gave me the same error about parsing it out.
