C# Help Blank Title 100416
That did the trick!!
Thank you!!
Sent: Wed, May 11, 2011 11:16:35 AM
Subject: Re: [Vantage] C# Help
Â
Okay --- I think I'm going a bit loopy looking at this code ---
When I do that the colors don't show like I have the syntax right, but then for
the heck of it I tried to see if it complied -- and it did?? I'm going to run
some tests,...but I think I've been trusting the color-coding more than I should
have been.
Live and Learn,...Â
Sent: Wed, May 11, 2011 10:59:48 AM
Â
the syntax inside the split is single quote slash slash single quote.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Wed, May 11, 2011 at 11:58 AM, Jose Gomez <jose@...> wrote:
> sNewPartDescription =
> (string)dsPart.Tables["Part"].Rows[0]["PartDescription"];
> sNewPartDescription = sNewPartDescription.Split('\\'')[1];
> That would work as long as the data you want is always after the first \
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
Hi there ---
I'm looking for a little programming help,....
I've got a field I want to extract some data from based on delimiters and the
custom code was written in c#.
ex --- (33" \ this is the data I want to grab \ this is the data I don't want)
I want to grab the data in the middle of the '\' --- and sometimes the field
only has the first '\', to make things a bit more challanging.
Thanks in Advance,
Laurie
String[] data = "ex --- (33" \ this is the data I want to grab \ this is the
data I don't want)".Split('\');
data[1] <= here is your data...
If its not always on the same position let me know. Also give a better
example. Put the string in between quotes so that we can know what you need.
And if you have more than one example that would be good
*Jose C Gomez*
Software Engineer
E: jose@...
On Wed, May 11, 2011 at 10:48 AM, stcsgirl <stcsgirl@...> wrote:
> Hi there ---
> the
> want)
> field
> Thanks in Advance,
> Laurie
String.Split function will do it.
It'll cut the string into an array of strings. Just take the 2nd one.
Damn, Gomez was faster.
> Hi there ---
> the
> want)
> field
> Thanks in Advance,
> Laurie
Ok --- you were both really fast in answering --- thank you!
Here is the code I currently have in my program,...and it grabs the data after
the first '\', but does not take the data away after the second '\', which I do
get I don't have in there to do that, as the reason I'm in here trying to change
that.Â
   sNewPartDescMinusSize =
sNewPartDescription.Substring(sNewPartDescription.IndexOf("\"") + 1) ;
The String.Split sounds just what I need --- not sure how to write that up
correctly -- I'm getting errors.
Sent: Wed, May 11, 2011 9:52:39 AM
> Hi there ---
> the
> want)
> field
> Thanks in Advance,
> Laurie
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
http://groups.yahoo.com/group/vantage/files/.%c2%a0
*Jose C Gomez*
*Software Engineer*
E: jose@...
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
have been.
Live and Learn,...Â
Â
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
