C# help - GL Side effect AP Invoice
Hi all,
Hope everyone is having a great Holiday Season!  I'm struggling with some C# code and need some help. In AP Invoice Entry I need to put the invoice on hold for a review process if any of the following conditions are met: Received Qty > PO Qty, Invoice Unit cost > PO Unit Cost, Invoice Ext Cost > PO Ext cost. I wrote the following C# code which works and will put the invoice on hold. The problem is I am having an unanticipated side effect. When I use this code I am unable to change, view or maintain the GL Account under the GL Analysis Tab.  If I enter a misc line, I just get a gray box, that doesn't show anything and doesn't allow any updates. Any thoughts or help would be greatly appreciated, I'm by no means a programmer, so forgive me if my function isn't written properly! - Bobby
private void baseToolbarsManager_ToolClick(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs args)
//  MessageBox.Show("Got Here1");
if(args.Tool.Key.ToString()=="SaveTool") // Action will only run when the save button is clicked
bool holdInvoice = false; //Set holdinvoice variable to false. the program will set to true if any of the conditions are met
EpiDataView edvInvHed = ((EpiDataView)(oTrans.EpiDataViews["APInvHed"]));
if (!edvInvHed.HasRow) //Check to see if there is a row in the Epi Dataview, if not then return, nothing to do until data is present.
{ return;}
if ((bool)edvInvHed.dataView[edvInvHed.Row]["InvoiceHeld"] ){
return; //Invoice is already on hold don't need to show message again
int PONum = Convert.ToInt32(edvInvHed.dataView[edvInvHed.Row]["REFPONum"]); //Get PO Number from invoice header
if(PONum != null && PONum != 0) // Check to see if PO number is legit
EpiDataView edvInvDtl = ((EpiDataView)(oTrans.EpiDataViews["APInvDtl"]));
foreach(DataRow row in edvInvDtl.dataView.Table.Rows)
//declare variables to use in calculations
double poRelQty = Convert.ToDouble(row["PORelQty"].ToString());
double scrVendorQty = Convert.ToDouble(row["ScrVendorQty"].ToString());
double scrUnitCost = Convert.ToDouble(row["ScrUnitCost"].ToString());
double poUnitCost = Convert.ToDouble(row["POUnitCost"].ToString());
double scrExtCost = Convert.ToDouble(row["ScrExtCost"].ToString());
double poReceivedQty = Convert.ToDouble(row["POReceivedQty"].ToString());
string partnum = Convert.ToString(row["PartNum"].ToString());
if((poReceivedQty > poRelQty) && partnum != "Sales Tax")
holdInvoice = true;
else if((scrUnitCost > (poUnitCost + 0.50)) && partnum != "Sales Tax")
holdInvoice = true;
else if((scrExtCost > Math.Round(((poRelQty * poUnitCost) + 0.50),2)) && partnum != "Sales Tax")
holdInvoice = true;
else {holdInvoice = true;}
if(holdInvoice == true)
//EpiDataView edvInvHed = ( (EpiDataView) (oTrans.EpiDataViews["APInvHed"]));
if((bool)edvInvHed.dataView[edvInvHed.Row]["Checkbox02"]) {
return; // it' s approved
else if((bool)edvInvHed.dataView[edvInvHed.Row]["DebitMemo"]) {
return; //Don't need to put a hold on for debit memo's
MessageBox.Show("Invoice will be put on hold, as it requires approval.");
edvInvHed.dataView[edvInvHed.Row]["InvoiceHeld"] = true;
else {return;}
