C# simple math - 905.700C
I will try that. I was sending my routine up, but it failed, so in the meantime I found online that if I initialized the values with m after the value it will make them decimal and not default to double, so I changed back to decimal.
The calculations are working and I just have some cleanup, so I can present tomorrow.
Thanks for your help.
Greg
// Custom code for UD04Form
// Created: 2/14/2013 11:58:14 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Epicor.Mfg.BO;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.Searches;
using Infragistics.Shared;
using Infragistics.Win;
using Infragistics.Win.UltraWinToolbars;
using Infragistics.Win.UltraWinDock;
public class Script
this.btnPartNum.Click += new System.EventHandler(this.btnPartNum_Click);
this.btnClear.Click += new System.EventHandler(this.btnClear_Click);
this.btnCalc.Click += new System.EventHandler(this.btnCalc_Click);
this.txtLocation.AfterExitEditMode += new System.EventHandler(this.txtLocation_AfterExitEditMode);
this.txtPartNum.AfterExitEditMode += new System.EventHandler(this.txtPartNum_AfterExitEditMode);
//Hide the top Toolbar
baseToolbarsManager.Visible = false;
this.btnPartNum.Click -= new System.EventHandler(this.btnPartNum_Click);
this.btnClear.Click -= new System.EventHandler(this.btnClear_Click);
this.btnCalc.Click -= new System.EventHandler(this.btnCalc_Click);
this.txtLocation.AfterExitEditMode -= new System.EventHandler(this.txtLocation_AfterExitEditMode);
this.txtPartNum.AfterExitEditMode -= new System.EventHandler(this.txtPartNum_AfterExitEditMode);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void UD04Form_Load(object sender, EventArgs args)
// Add Event Handler Code
Epicor.Mfg.UI.FrameWork.EpiTreeViewPanel TreeViewPanel = (Epicor.Mfg.UI.FrameWork.EpiTreeViewPanel)csm.GetNativeControlReference("d3a4fa73-e037-484e-8c93-1f930be38abf");
Epicor.Mfg.UI.App.UD04Entry.MainPanel MainPanel = (Epicor.Mfg.UI.App.UD04Entry.MainPanel)csm.GetNativeControlReference("1dff11bc-3024-4d17-acfc-b7af287e274b");
TreeViewPanel.Dispose();
MainPanel.Dispose();
// intialize Values
numLaborRate.Value = .45m;
numScrapPct.Value = 1m;
numFreightPct.Value = 2m;
numResale.Value = 0m;
numMaterialCost.Value = 0m;
numLaborMinutes.Value = 0m;
numLaborCost.Value = 0m;
numScrapCost.Value = 0m;
numFreightCost.Value = 0m;
numTotalCost.Value = 0m;
numGPDollars.Value = 0m;
numGPPct.Value = 0m;
numGPPerHr.Value = 0m;
//numTotalCost.Value = (decimal)numLaborCost.Value + (decimal)numMaterialCost.Value; //+ (decimal)numScrapCost.Value + (decimal)numFreightCost.Value;
private void txtPartNum_AfterExitEditMode(object sender, System.EventArgs args)
bool oBool = false;
DataSet ds = new DataSet();
ds = SearchFunctions.listLookup(oTrans, "PartAdapter", out oBool, false, "");
try
if(ds.Tables[0].Rows.Count > 0)
txtPartNum.Text = ds.Tables[0].Rows[0]["PartNum"].ToString();
txtPartNumDesc.Text = ds.Tables[0].Rows[0]["PartDescription"].ToString();
numLaborMinutes.Value = ds.Tables[0].Rows[0]["Number01"];
numResale.Value = ds.Tables[0].Rows[0]["UnitPrice"];
catch{}
private void btnPartNum_Click(object sender, System.EventArgs args)
bool oBool = false;
ds = SearchFunctions.listLookup(oTrans, "PartAdapter", out oBool, true, "");
try
catch{}
private void txtLocation_AfterExitEditMode(object sender, System.EventArgs args)
if ((txtLocation.Text.IndexOf("FIN50") != -1) || (txtLocation.Text.IndexOf("FIN6") != -1) || (txtLocation.Text.IndexOf("FIN7") != -1))
numLaborRate.Value = .40m;
if (txtLocation.Text.IndexOf("FIN502") != -1)
numLaborRate.Value = .37m;
if (txtLocation.Text.IndexOf("FIN00") != -1)
numLaborRate.Value = .55m;
if (txtLocation.Text.IndexOf("FIN004") != -1)
numLaborRate.Value = .4m;
if (txtLocation.Text.IndexOf("FIN005") != -1)
private void btnClear_Click(object sender, System.EventArgs args)
numLaborRate.Value = .45;
// intialize Values
private void btnCalc_Click(object sender, System.EventArgs args)
numScrapCost.Value = (decimal)numMaterialCost.Value * ((decimal)numScrapPct.Value / 100 );
numFreightCost.Value = (decimal)numMaterialCost.Value * ((decimal)numFreightPct.Value / 100);
numLaborCost.Value = (decimal)numLaborMinutes.Value * (decimal)numLaborRate.Value;
numTotalCost.Value = (decimal)numLaborCost.Value + (decimal)numMaterialCost.Value +
numTotalCost.Value = (decimal)numLaborCost.Value + (decimal)numMaterialCost.Value + (decimal)numScrapCost.Value + (decimal)numFreightCost.Value;
numGPDollars.Value = (decimal)numResale.Value - (decimal)numTotalCost.Value;
if ((decimal)numResale.Value > 0.0m)
numGPPct.Value = ((decimal)numGPDollars.Value / (decimal)numResale.Value * 100);
if ((decimal)numLaborMinutes.Value != 0m)
numGPPerHr.Value = (60/(decimal)numLaborMinutes.Value) * ((decimal)numResale.Value - (decimal)numTotalCost.Value);
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Sean McDaniel
Sent: Monday, February 25, 2013 4:09 PM
Subject: RE: [Vantage] C# simple math - 905.700C
Sorry, had a moment :o)
Probably might try this:
numTotalCost.value = (double.Parse(numLaborCost.Value) + double.Parse(nummaterialCost.Value)).ToString();
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> on behalf of Greg Payne
Sent: Mon 2/25/2013 2:43 PM
Subject: [Vantage] C# simple math - 905.700C
I am trying to write a simple margin calculator on the UD04 screen. I have numeric fields all set as double ( I also tried decimal).
I have several inputs and then 4 calculations on submit. it fails with a casting exception and after trying to learn C# on the fly today I am still clueless.
Can I get a simple example of how to make the addition below work?
Greg Payne
numMaterialCost.Value = 10;
numLaborCost.Value = 4.5;
numTotalCost.Value = (double)numLaborCost.Value + (double)numMaterialCost.Value;
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Greg Payne
If you can supply the code that you're having issues with it would be easier to help you.
From: vantage@yahoogroups.com on behalf of Greg Payne
Greg Payne
Greg Payne
the on click was getting the error, so I copied the calculations and preset the values in the on load.
The fields are not bound to a UD04 field.
Thanks for the help.
Greg
//numScrapCost.Value = (decimal)numMaterialCost.Value * ((decimal)numScrapPct.Value * 100 );
//numFreightCost.Value = (decimal)numMaterialCost.Value * ((decimal)numFreightPct.Value * 100);
//numLaborCost.Value = (decimal)numLaborMinutes.Value * (decimal)numLaborRate.Value;
//numTotalCost.Value = (decimal)numLaborCost.Value + (decimal)numMaterialCost.Value +
//(decimal)numScrapCost.Value + (decimal)numFreightCost.Value;
numTotalCost.Value = (double)numLaborCost.Value + (double)numMaterialCost.Value + (double)numScrapCost.Value + (double)numFreightCost.Value;
//numGPDollars.Value = (decimal)numResale.Value - (decimal)numTotalCost.Value;
if ((int)numResale.Value != 0)
numGPPct.Value = (decimal)numGPDollars.Value / (decimal)numResale.Value;
if ((int)numLaborMinutes.Value != 0)
// intialize Values
numScrapPct.Value = 1;
numFreightPct.Value = 2;
numResale.Value = 25.00;
numLaborMinutes.Value = 10;
numLaborCost.Value = 0;
numScrapCost.Value = 0;
numFreightCost.Value = 0;
numTotalCost.Value = 0;
numGPDollars.Value = 0;
numGPPct.Value = 0;
numGPPerHr.Value = 0;
numTotalCost.Value = (double)numLaborCost.Value + (double)numMaterialCost.Value; //+ (double)numScrapCost.Value + (double)numFreightCost.Value;
Sent: Monday, February 25, 2013 4:08 PM
Greg Payne
