Syntax is okay but when I try to run it I get this error:
Severity: Error, Table: , Field: , RowID: , Text: Bad SQL statement.
Review the server event logs for details.
Query returned 0 row(s).
Query has no more records to return.
Query execution total time: 39.5891 ms.
Works fine after I remove the third line with the string. Is there a limit on the amount of functions I can run or am I writing something wrong? Any help would be greatly appreciated, thank you.
Give this a try and wrap your numbers in ’ ’ and you cannot drop a NULL without ’ ’ or you must wrap that calculated field in a ISNULL or use COALESCE
SELECT TOP(5) PartNum,
(CASE
WHEN Erp.Part.PartNum like '%SC228%' then '1'
WHEN Erp.Part.PartNum like '%CM30%' then '2'
WHEN Erp.Part.PartNum like '%MB3130%' then 'tt'
else 'NULL' end) as Calc_Field1
FROM Erp.Part
If you’re going to use LIKE I would use a % as a wildcard. If you’re going to tell SQL what the context of that field is going to be then you’re better of using equal symbol
