We have heavily customized the Purchase Advisor screen.
Added boxes for Std Cost, and ytd usage, prev ytd usage and 2yr ago usage. Added tabs to display legacy data stored in UD14, Time Phase info and Where used info. And we use UD10 to store part sourcing info. You can weed out what you don't need. This is V8.03.405a.
'// Custom VB.NET code for PurchaseAdvisorEntryForm
'// Created: 5/14/2007 1:25:10 PM
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
Imports Epicor.Mfg.BO
Module Script
'// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
'// Begin Wizard Added Module Level Variables **
Private WithEvents PartList_DataView As DataView
Private WithEvents edvPartList As EpiDataView
'// End Wizard Added Module Level Variables **
'// Add Custom Module Level Variables Here **
Private WithEvents partAdapter As PartAdapter
Dim dsWhereUsedData As DataSet
Private WithEvents edvWhereUsed As EpiDataView
Private WithEvents timephasAdapter As TimePhasAdapter
Private WithEvents edvTimePhas As EpiDataView
Sub InitializeCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
'// Begin Wizard Added Variable Intialization
edvPartList = CType(oTrans.EpiDataViews("PartList"), EpiDataView)
'// End Wizard Added Variable Intialization
'// Begin Custom Method Calls
InitializeProcCallDataViews()
partAdapter = New partAdapter(oTrans)
partAdapter.BOConnect()
edvWhereUsed = new EpiDataView()
edvWhereUsed.dataview = new DataView(partAdapter.WhereUsedData.PartWhereUsed)
if not (oTrans.EpiDataViews.ContainsKey("WUView")) then oTrans.Add("WUView",edvWhereUsed)
timephasAdapter = New timephasAdapter(oTrans)
timephasAdapter.BOConnect()
edvTimePhas = new EpiDataView()
edvTimePhas.dataView = New DataView(timephasAdapter.TimePhasData.TimePhas)
If Not (oTrans.EpiDataViews.ContainsKey("TimePhasView")) Then oTrans.Add("TimePhasView",edvTimePhas)
'// End Custom Method Calls
End Sub
Sub DestroyCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
'// Begin Wizard Added Object Disposal
'// End Wizard Added Object Disposal
'// Begin Custom Code Disposal
partAdapter.Dispose()
partAdapter = Nothing
edvWhereUsed = Nothing
timephasAdapter.Dispose()
timephasAdapter = Nothing
edvTimePhas = Nothing
'// End Custom Code Disposal
End Sub
Private Sub InitializeProcCallDataViews()
Dim whereClause As String
whereClause = "Key1 ='$%' And Key2 ='$%' And Key3 ='$%' And Key4 ='$%' And Key5 ='$%'"
csm.UpdateProcCallDataView("UD14Adapter","UD14",whereClause,"UD14View",True)
csm.UpdateProcCallDataView("UD10Adapter","UD10",whereClause,"UD10View",True)
End Sub
Private Sub PartList_AfterFieldChange(ByVal sender As object, ByVal args As DataColumnChangeEventArgs) Handles PartList_Column.ColumnChanged
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "PartNum"
'Dim whereClause As String
' whereClause = "Key1 ='" + args.ProposedValue + "'"
' csm.UpdateProcCallDataView("UD14Adapter","UD14",whereClause,"UD14View",False)
' Dim ldopy as date = DateAdd(DateInterval.Second, -3, DateAdd(DateInterval.Year, DateDiff(DateInterval.Year, Date.MinValue, Now()), Date.MinValue))
' Dim ldoppy as date = DateAdd(DateInterval.Year, -1, ldopy)
'Dim whereClause1 As String = "PartNum = '" + args.ProposedValue.ToString() + "' AND TranType = 'STK-MTL' AND TranDate > '" + ldopy + "'"
' txtUprev.Text = ytdUsage("PartNum = '" + args.ProposedValue.ToString() + "' AND TranType = 'STK-MTL' AND TranDate > '" + ldoppy + "' AND TranDate <= '" + ldopy + "'").ToString()
' txtUytd.Text = ytdUsage("PartNum = '" + args.ProposedValue.ToString() + "' AND TranType = 'STK-MTL' AND TranDate > '" + ldopy + "'").ToString()
' txtStdCost.Text = getStdCost(args.ProposedValue.ToString()).ToString()
Case Else
End Select
End Sub
Private Function ytdUsage (ByVal clause As string) As Integer
Dim ytdUsed As Integer = 0
Dim recSelected As Boolean
Dim dsSearch As DataSet
dsSearch = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "PartTranHistAdapter", recSelected, False, clause, True)
If recSelected Then
For Each dr As DataRow In dsSearch.Tables(0).Rows
ytdUsed = ytdUsed + dr("TranQty")
Next
End If
Return ytdUsed
End Function
Private Function getStdCost(ByVal pn as String) As Decimal
Dim stdCost As Decimal = 0
Dim recordSelected As Boolean
Dim showSearch As Boolean = False
Dim whereClause As String = "partNum = '" & pn & "' And costID = '1'"
Dim dsCost As DataSet = SearchFunctions.listLookup(PurchaseAdvisorEntryForm, "PartCostSearchAdapter", recordSelected, showSearch, whereClause)
If (recordSelected = True)
stdCost = dsCost.Tables(0).Rows(0)("StdMaterialCost")
End If
Return stdCost
End Function
Private Sub edvPartList_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvPartList.EpiViewNotification
'// view.dataView(args.Row)("PartNum")
'// args.Row, args.Column, args.Sender, args.NotifyType
'// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
If (args.NotifyType = EpiTransaction.NotifyType.Initialize) Then
partAdapter.clearData()
timephasAdapter.clearData()
edvWhereUsed.EpiDataChanged()
edvTimePhas.EpiDataChanged()
If (args.Row > -1) Then
whereClause = "Key1 ='" + view.dataView(args.Row)("PartNum") + "'"
whereClause = "Key1 ='" + view.dataView(args.Row)("PartNum") + "' BY INT(Key2)"
csm.UpdateProcCallDataView("UD10Adapter","UD10",whereClause,"UD10View",False)
Dim morePages as Boolean
Dim dsWhereUsed As DataSet = partAdapter.GetPartWhereUsed(view.dataView(args.Row)("PartNum"),0,1,morePages)
Dim blTimePhas As Boolean = timephasAdapter.GoProcessTimePhase(view.dataView(args.Row)("PartNum"), "MfgSys", False, False)
Dim ldopppy as date = DateAdd(DateInterval.Year, -1, ldoppy)
txt2YrAgo.Text = ytdUsage("PartNum = '" + view.dataView(args.Row)("PartNum").ToString() + "' AND TranType = 'STK-MTL' AND TranDate > '" + ldopppy + "' AND TranDate <= '" + ldoppy + "'").ToString()
txtUprev.Text = ytdUsage("PartNum = '" + view.dataView(args.Row)("PartNum").ToString() + "' AND TranType = 'STK-MTL' AND TranDate > '" + ldoppy + "' AND TranDate <= '" + ldopy + "'").ToString()
txtUytd.Text = ytdUsage("PartNum = '" + view.dataView(args.Row)("PartNum").ToString() + "' AND TranType = 'STK-MTL' AND TranDate > '" + ldopy + "'").ToString()
txtStdCost.Text = getStdCost(view.dataView(args.Row)("PartNum")).ToString()
End If
End If
End Sub
Private Sub ugdTimePhase_BackColorChanged(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles ugdTimePhase.BackColorChanged
'// ** Place Event Handling Code Here **
If ugdTimePhase.BackColor <> System.Drawing.Color.Silver Then
ugdTimePhase.BackColor = System.Drawing.Color.Silver
End If
End Sub
Private Sub ugdEpiCustom1_BackColorChanged(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles ugdEpiCustom1.BackColorChanged
If ugdEpiCustom1.BackColor <> System.Drawing.Color.Silver Then
ugdEpiCustom1.BackColor = System.Drawing.Color.Silver
End If
End Sub
End Module
--- In vantage@yahoogroups.com, "tracy.tmat" <tracy.smith@...> wrote:
> I want to show the Std part cost on the Purchase Advisor but am unsure on the best way... a BPM that updates a UD field on the Part Table or Foreign Key/Calculated field on the form?
> The problem with the foreign key is that I can't get to the PartCost table as far as I can see... any suggestions?
> We're on 8.03.409a. Thanks.
