Call BO method from within BPM
Thanks, too bad the closejob was not like getbyid it needs some pre close message from the preclosejob method and then I just get all confused at that point :)
--- In vantage@yahoogroups.com, "Dale Schuerman" <dale.schuerman@...> wrote:
> Michael,
> The only way I have gotten this to work is to:
> Copy /mfgsys803/server/ud/test/RunBOThruGL.p and modify it to run your
> JobClosing processing(Business Objects).
> Then in the BPM add a line to Run /xxxx/xxxx/xxxxxx.p. (Whatever you
> called your new program)
> Hope this helps,
> Dale E. Schuerman
> Senior Consultant
> Epicor Certified Consulting Partner
> RAM Software Systems, Inc.
> 972-669-0763 x233 (voice)
> 972-669-9603 (fax)
> mailto:dale.schuerman@...
> <BLOCKED::blocked::mailto:dale.schuerman@...> (email)
> http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/>
> (website)
> Of Michael McWilliams
> Sent: Friday, July 31, 2009 1:04 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Call BO method from within BPM
> I have a BPM on a UD table & from within my BPM I would like to run the
> CloseJob method from JobClosing BO for each record. Can I do this?
> Attention:
> This email message is privileged and confidential. If you are not the
> intended recipient please delete the message and notify the sender.
> Any views or opinions presented are solely those of the author.
> This email message has been scanned for Viruses and Content and cleared
> by MailMarshal SMTP
> For more information go to http://www.ramsys.com
I have a BPM on a UD table & from within my BPM I would like to run the CloseJob method from JobClosing BO for each record. Can I do this?
Michael,
Hope this helps,
Dale E. Schuerman
Senior Consultant
972-669-9603 (fax)
(website)
Attention:
by MailMarshal SMTP
