Bruce,
If it is only for a FKV then you can just create a subtable FKV from order
entry. Then you will not any customizations.
You create a main FKV for the Part table and then create another sub FKV and
select a PartPlant table. From there the sub table fields will be available
in the new FKV.
Ross
cooner_55421
Sent: Friday, June 25, 2010 3:34 PM
Subject: [Vantage] Re: Call for a simple? example
Hi Ross,
Thanks, I'll give this a try.
I am using Number20 in the Part table but it doesn't have to update during
entry.
I just want the value for a foreign key view on the sale order entry, line
screen.
We're trying to get service to push the need-by date out if there is nothing
on hand.
They might start doing it if we make the lead-time visible....
Still here for the summer...
Bruce
in the new FKV.
Ross
cooner_55421
Hi Ross,
entry.
screen.
on hand.
Bruce
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> Hi Bruce,
> I would do this as a client customization because you want the part field
to
> change right after the lead time field changes. BPM's trigger on
> object/methods and not field changes. A multi-plant scenario may give
> unpredictable results.
> I wrote something that should work for you. Create a part customization
and
> paste the following code right before the final End Module line.
> Private Sub PartPlant_AfterFieldChange(ByVal sender As object, ByVal
> args As DataColumnChangeEventArgs) Handles PartPlant_Column.ColumnChanged
> '// ** Argument Properties and Uses **
> '// args.Row("[FieldName]")
> '// args.Column, args.ProposedValue, args.Row
> 'Add Event Handler Code
> Select Case args.Column.ColumnName
> Case "LeadTime"
> Dim edvPartPlant As EpiDataView =
> CType(oTrans.EpiDataViews("PartPlant"), EpiDataView)
> Dim intLeadTime As Int32 =
> edvPartPlant.dataView(edvPartPlant.Row)("LeadTime")
> Dim edvPart As EpiDataView =
> CType(oTrans.EpiDataViews("Part"), EpiDataView)
> edvPart.dataView(edvPart.Row)("Number20") = intLeadTime
> edvPart.Notify( New EpiNotifyArgs(oTrans, edvPart.Row,
> edvPart.Column) )
> Case Else
> End Select
> End Sub
> Be careful for line wraps.
> I am assuming here you are using Number20 in the Part table. If you are
> using a different field and having trouble, I can tailor it if needed.
> Hope this helps,
> Ross
Of
> cooner_55421
> Sent: Wednesday, June 23, 2010 2:39 PM
> Subject: [Vantage] Call for a simple? example
> Hi,
> Help... I am looking for an example.
> When I update the lead-time in the Part Plant screen, I would like the
> system to copy that value and use it to update a user defined field in the
> Part table.
> Would you use a BPM, screen customization, something else?
> Thanks in advance.
> Bruce
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
