And that will return records to the screen? Good deal, I wasn't sure if it would I couldn't get it to return data from a BAQ search
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> If you make the Quick Search the base search then using a simple search
> this will work. However if you want to call a Quick Search from code which
> is not your main search. Then you need to use a Named Search instead.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Thu, Oct 11, 2012 at 8:51 AM, Anon
> <epicor-team@...>wrote:
> > Is there a way to call a specific quick search from code? We have a field
> > in the Part table that we use to record serial numbers of printing plates
> > that go with that part (the numbers basically identify the specific art
> > work for that part). I would like to add a button next to that field that
> > allows for searching (using a quick search) of other parts with the same
> > artwork, selecting one of those parts, then auto filling some other custom
> > fields that hold the same properties.
> > This is kind of our own custom configurator, it was more than we could
> > take on during implementation, and configurator is more than we need, so we
> > added some custom field to do the in-between.
