Calling a BPM from a Method - does it invoke other BPMs?
I'm pretty sure the BPMs only fire if you call the methods at a higher
level.
On Thu, Jul 28, 2011 at 6:57 AM, Rupert <r.oo@...> wrote:
> If I have a BPM that, for example calls a method to automatically create a
> job, will other BPMs work as they do with manual inputs.
> ie if I have BPMs that are within the update Job procedure. when I run the
> BPM that creates a Job would that invoke the update BPM?
> At the moment we have one that does this but other connected BPMs are not
> running - I'm not sure if this correct or not?
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
If I have a BPM that, for example calls a method to automatically create a job, will other BPMs work as they do with manual inputs.
ie if I have BPMs that are within the update Job procedure. when I run the BPM that creates a Job would that invoke the update BPM?
At the moment we have one that does this but other connected BPMs are not running - I'm not sure if this correct or not?
