/* Macroscoop: www.macroscoop.nl
Program: External.p
Version: 5.00.312 - 1.0
written by R.J. van der Linden
mailto:R.van.der.Linden@...
You can put copies of this program in the Vantage\UD
directory. Do not forget that the first two letters of the
program name have to be 'UD'
DEFINE VARIABLE ProgName AS CHARACTER NO-UNDO.
DEFINE VARIABLE ProgOption AS CHARACTER NO-UNDO.
DEFINE VARIABLE hInstanceNum AS INTEGER NO-UNDO.
/* if the program or document has spaces in its name
then you have to put double quotes around it
like the document example:
ASSIGN ProgName = 'winword.exe'
ProgOption = '"c:\eManufacturing TEST Document.doc"'.
ShellExec knows location of the vantage directory.
If you put your documents in a directory called Vantage\Docs
then program option could be:
ProgOption = '"Docs\eManufacturing TEST Document.doc"'.
ASSIGN ProgName = 'msaccess.exe'
ProgOption = 'v:\vantage\ud\DocMang\JobAtt\access\jobatt.mde'.
RUN v:\vantage\lib\ShellExec.r (INPUT ProgName,
INPUT ProgOption,
OUTPUT hInstanceNum).
/* lib\ShellExec.p is a program of Epicor */
/*DOS SILENT v:\custom\FORM\SODoc\access\VIEW.mde*/
Above is the code that was shared with me.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Tuesday, July 30, 2002 10:47 AM
Subject: [Vantage] calling a exe from a .p file
Can anyone tell me how to call an external .exe file from a .p file in
procedure editor?
Britt Moelling
M&M Manufacturing Co.
Program: External.p
INPUT ProgOption,
Jeremy Leonard
IT Manager
K-T Corporation
procedure editor?
Britt Moelling
