Calling UD Form - Multiple Keys
Hi,
Thanks for the below, I wasn't aware that hashing was available. I
will see if I can use that .
Thanks again for the insights.
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> I think you might be out of luck there. I tried creating a
hashtable
> of values to send as value in, and an array to send as value in.
> Neither worked.
> I guess you can go the 'Brute Force' way of doing it.
> Create a blank panel in your form, add appropriate adapters
display,
> enter the data needed for your UD table in that panel without
> invoking the UD Form.
> That is what we have done on our Part Entry form to display, add,
> edit, delete UD10 data which we are using as our Manufacturer's
Part
> Number info (Can't wait to see that functionality in 9)
> bw
> --- In vantage@yahoogroups.com, "brychanwilliams"
> <brychanwilliams@> wrote:
> > Hi,
> > Thanks for the below, I use the method below but I can't work out
> how
> > to pass multiple keys to the process caller. I am not sure if can
> be
> > done or not but it would seem strange if it can't .
> > Thanks again.
> > --- In vantage@yahoogroups.com, "mretzlercooper" <mretzler@>
wrote:
> > > This is how I launch a the UD11 form from SalesOrderForm with a
> > value
> > > being passed in (I only use Key1 in UD11)
> > > Dim lfo As LaunchFormOptions = New LaunchFormOptions()
> > > lfo.IsModal = true
> > > lfo.SuppressFormSearch = true
> > > lfo.ValueIn = "UD11KeyOfRecordIWantToDisplay"
> > > ProcessCaller.LaunchForm
> (SalesOrderForm, "Epicor.Mfg.UI.UD11Entry",
> > > lfo)
> > > I am not sure if you can set ValueIn to an array of values or
> > > something, but you may want to look closer at that.
> > > > Hi, Thanks for the prompt reply. I have should have been
> clearer.
> > > > What I want to achieve is the following;
> > > > 1) In Project Entry, at a button click, create a project
budget
> > > > create the records as below. I can do that and then launch
the
> > form
> > > > so the that the rest of the information can be filled out.
> > > > 2) As the budget changes affectively new records will be
> entered.
> > > > I am using processcaller.launchform statements...
> > > > Thanks again.
> > > > --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > > > > Not sure how you are calling in the UD data, but the
GetList
> > > method
> > > > and
> > > > > GetRows method both take a query "Key1 = 'abc' AND Key2
> = 'xyz'
> > > AND
> > > > > Key3 = 'Open'"
> > > > > The listLookup will use the same kind of query in the
> > whereClause
> > > > > bw
> > > > <brychanwilliams@>
> > > > > wrote:
> > > > > > Hi,
> > > > > > I am trying to use a UD table to store multiple versions
of
> a
> > > > project
> > > > > > Budgets. I was planning to use Key 1 as the project
code ,
> > Key
> > > 2
> > > > as
> > > > > the
> > > > > > project budget type and key 3 as the budget status.
> > > > > > I can call the UD form from the project entry screen if I
> > just
> > > > use
> > > > > key1
> > > > > > but I would like more control and be able to pass all
three
> > > keys
> > > > > > through. My mind is a blank on this...
> > > > > > Thanks for any help in advance.
Hi,
I am trying to use a UD table to store multiple versions of a project
Budgets. I was planning to use Key 1 as the project code , Key 2 as the
I can call the UD form from the project entry screen if I just use key1
but I would like more control and be able to pass all three keys
Not sure how you are calling in the UD data, but the GetList method and
GetRows method both take a query "Key1 = 'abc' AND Key2 = 'xyz' AND
Key3 = 'Open'"
The listLookup will use the same kind of query in the whereClause
bw
--- In vantage@yahoogroups.com, "brychanwilliams" <brychanwilliams@...>
wrote:
> Hi,
the
key1
Hi, Thanks for the prompt reply. I have should have been clearer.
1) In Project Entry, at a button click, create a project budget
create the records as below. I can do that and then launch the form
2) As the budget changes affectively new records will be entered.
Thanks again.
and
> Key3 = 'Open'"
> bw
<brychanwilliams@>
> wrote:
> > Hi,
project
as
> the
use
> key1
This is how I launch a the UD11 form from SalesOrderForm with a value
lfo.IsModal = true
ProcessCaller.LaunchForm(SalesOrderForm, "Epicor.Mfg.UI.UD11Entry",
lfo)
> Thanks again.
method
> and
AND
> > Key3 = 'Open'"
> > bw
> <brychanwilliams@>
> > wrote:
> > > Hi,
> project
2
> as
> > the
> use
> > key1
keys
Hi,
Thanks for the below, I use the method below but I can't work out how
to pass multiple keys to the process caller. I am not sure if can be
Thanks again.
value
> lfo.IsModal = true
> lfo)
form
> > Thanks again.
> method
> > and
> AND
> > > Key3 = 'Open'"
whereClause
> > > bw
> > <brychanwilliams@>
> > > wrote:
> > > > Hi,
> > project
Key
> 2
> > as
> > > the
just
> > use
> > > key1
> keys
I think you might be out of luck there. I tried creating a hashtable
Neither worked.
Create a blank panel in your form, add appropriate adapters display,
edit, delete UD10 data which we are using as our Manufacturer's Part
bw
> Hi,
how
be
> Thanks again.
> value
> > lfo.IsModal = true
> > lfo)
clearer.
> form
entered.
> > > Thanks again.
> > method
> > > and
= 'xyz'
> > AND
> > > > Key3 = 'Open'"
> whereClause
> > > > bw
> > > <brychanwilliams@>
> > > > wrote:
> > > > > Hi,
a
> > > project
> Key
> > 2
> > > as
> > > > the
> just
> > > use
> > > > key1
> > keys
