Can I change part name?
Thanks Joshua,
I was thinking if I will get any positive response for BAQ but I think except creating new parts there is no hope :-(
--- In vantage@yahoogroups.com, Joshua Giese <jgiese@...> wrote:
> The Epicor BOs wouldn't let you even do that I don't think. I would hope
> at least. Changing a part number is some sticky business you pretty much
> can only back them out and create new ones.
> You could (and I warn this is a terrible idea) conceivably run SQL queries
> on every table with PartNum and replace the bad part with the good part.
> There is a Data Dictionary field cross reference in the files section that
> has every table X field is in.
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> Of Kiran
> Sent: Thursday, August 8, 2013 1:17 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Can I change part name ?
> Hi Jose,
> Yes, Epicor also gave me this solution. So you mean there is no way to
> rename the part number.
> Do you have any idea like if we can do this through updatable BAQ as we
> can edit other records ???
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jose
> Gomez <jose@ <mailto:jose@> > wrote:
> > I would create a new part number then adjust the old ones out and brink
> the
> > new ones in through Qty Adjustment.
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez>
> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez>
> <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > <http://www.usdoingstuff.com>
> > *Quis custodiet ipsos custodes?*
> > On Thu, Aug 8, 2013 at 2:06 PM, Kiran <saini.kiran17@
> <mailto:saini.kiran17@> > wrote:
> > > Hi friends,
> > > one of my colleague created some weird part numbers which contains
> special
> > > symbols like # and " . The problem is barcode generator does not
> generate
> > > barcodes for these types of symbols. So scanner can not scan the parts
> > > because barcode has special symbols as it as.
> > > So the barcode has barcodes for numbers and special symbols remain as
> it
> > > is. Each time when we create transfer order from Transfer Order Entry
> we
> > > have to enter these parts manually otherwise we use scanner for
> scanning
> > > part numbers.
> > > Does somebody any idea how I can change these part numbers & remove
> > > symbols from them ?
> > > Eg of part number : AAA#2111 22" - 23"-P
> > > Barcodes shows bars for alphabets n numbers but # and " remain as it
> is
> > > Thanks
> > > Kiran
Hi friends,
one of my colleague created some weird part numbers which contains special symbols like # and " . The problem is barcode generator does not generate barcodes for these types of symbols. So scanner can not scan the parts because barcode has special symbols as it as.
So the barcode has barcodes for numbers and special symbols remain as it is. Each time when we create transfer order from Transfer Order Entry we have to enter these parts manually otherwise we use scanner for scanning part numbers.
Does somebody any idea how I can change these part numbers & remove symbols from them ?
Barcodes shows bars for alphabets n numbers but # and " remain as it is ......
Kiran
I would create a new part number then adjust the old ones out and brink the
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Aug 8, 2013 at 2:06 PM, Kiran <saini.kiran17@...> wrote:
> Hi friends,
> part numbers.
> symbols from them ?
> Thanks
> Kiran
Hi Jose,
Yes, Epicor also gave me this solution. So you mean there is no way to rename the part number.
Do you have any idea like if we can do this through updatable BAQ as we can edit other records ???
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi friends,
> > part numbers.
> > symbols from them ?
> > Thanks
> > Kiran
There is no real way to do it. PartNum is spread all over epicor like
white on rice it would be very very hard to do it and to do it right.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Aug 8, 2013 at 2:16 PM, Kiran <saini.kiran17@...> wrote:
> Hi Jose,
> the
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hi friends,
> special
> generate
> it
> we
> scanning
> > > part numbers.
> > > symbols from them ?
> > > Thanks
> > > Kiran
Joshua Giese
CTO
Of Kiran
Hi Jose,
the
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
<mailto:saini.kiran17@...> > wrote:
> > Hi friends,
special
generate
it
we
scanning
> > part numbers.
> > symbols from them ?
is
> > Thanks
> > Kiran
Ohh ! That's weird.Anyways thanks for your support Jose .
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi Jose,
> > the
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Thu, Aug 8, 2013 at 2:06 PM, Kiran <saini.kiran17@> wrote:
> > > > Hi friends,
> > special
> > generate
> > it
> > we
> > scanning
> > > > part numbers.
> > > > symbols from them ?
> > > > Thanks
> > > > Kiran
