Can I do UOM Resverse from KG to Meters
> In Epicor 9 Can I do UoM Resverse from KG to Meters?
> Many thanks.
Not directly. Each UOM has to belong to one and only one UOM class. Within
each class, one chooses the "base UOM" and each other UOM has to have a
conversion factor to the base UOM. KG is generally a weight class and Meters
is a Length class, so there is no conversion between the two. (There's a
similar issue with volume vs weight OZs)
The only solution I can imagine is to make up a new UOM - say KGM within the
Length class and place your conversion factor there, then make sure that
your PUOM is the new KGM UOM.
Mark W.
Many thanks.
