One of Operator has completed 40 pcs yesterday ( I enter 1 qty to check, we have to update to add 39 pcs more as completed to the job) , he could not enter his qty. I tired to enter and check we can only qty 1, any thing over one we have the error message as below
So you went into Job Entry, unreleased/unengineered the job, clicked schedule>unscheduled job, then clicked the checkboxes to engineer it and release it which should prompt you to schedule it?
here is the error detail
Specified argument was out of the range of valid values.
Parameter name: Specified argument was out of the range of valid values.
Parameter name: Position is greater than number of delimited values
Message: Specified argument was out of the range of valid values.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.LaborImpl.Update(LaborDataSet ds)
at Erp.Adapters.LaborAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Erp.UI.App.TimeAndExpenseEntry.Transaction.Update()
Doesn’t seem to provide enough detail, seems to be missing the server stack trace.
You can try enabling server side logging through AppServer.config, this will generate file ServerLog.txt on the server deployment folder with more technical details.
You can also check windows event viewer to see if there is a more detailed error.
