Can not delete a shipment line
Anyone know why a shipment line can not be deleted? Please help
Business Layer Exception
Cannot delete shipping line.
Error Detail
Description: Cannot delete shipping line.
Program: Erp.Services.BO.CustShip.dll
Method: ShipDtlBeforeDelete
Line Number: 30173
Column Number: 17
Table: ShipDtl
Server Trace Stack: at Erp.Services.BO.CustShipSvc.ShipDtlBeforeDelete() in C:_Releases\ERP\UD10.1.500.7\Source\Server\Services\BO\CustShip\CustShip.cs:line 30173
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action) in C:_Releases\ICE\3.1.500.7\Source\Framework\Epicor.Ice\Services\TablesetProfilingCollector.cs:line 146
at Ice.TablesetBound3.DeleteRow(IceDataContext dataContext, String tableName, LinqRow dbRow, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1255 at Ice.TablesetBound3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:_Releases\ICE\3.1.500.7\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 905
at Ice.TablesetBound3.InnerUpdate(IceDataContext dataContext, TFullTableset tableset) in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 797 at Erp.Services.BO.CustShipSvc.Update(CustShipTableset& ds) in C:\_Releases\ERP\UD10.1.500.7\Source\Server\Services\BO\CustShip\CustShip.Designer.cs:line 2951 at Erp.Services.BO.CustShipSvcFacade.Update(CustShipTableset& ds) in C:\_Releases\ERP\UD10.1.500.7\Source\Server\Services\BO\CustShip\CustShipSvcFacade.cs:line 2427 at SyncInvokeUpdate(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:_Releases\ICE\3.1.500.7\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28 at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\3.1.500.7\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23 at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result) at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result) at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result) at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously) at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.CustShipImpl.Update(CustShipDataSet ds)
at Erp.Adapters.CustShipAdapter.OnDelete()
at Ice.Lib.Framework.EpiBaseAdapter.Delete(DataRow dr)
at Erp.UI.App.CustShipEntry.Transaction.Delete()
What is the status of the Pack?
Thank you Jason. I found it was zero quantity issue which can be fixed a data fix utility.
In our case, the status of the shipment (pack) has been changed back from “Shipped” to “Open”.
If the shipment has been in the Shipped status and then pack is open again (status Open), then when deleting the shipment lines, the message still appears:
I tried both classic and Kinetic mode, the error message is the same.
Currently, it is not possible to delete lines from a re-opened shipment so that the materials can be returned to the warehouse.
Maybe this is because the pack id of each line is linked to the PCID?
