Good morning,
Our engineers found an issue in some grids where some of the columns do not allow sorting. For example, go to Part Tracker > Activity > POs. Look down the list and find the Job, Asm, Op columns. Try sorting by any of these, or several other fields in this grid view. They do not allow sorting on some columns. Is this working as designed?
Thank you for your time!
Nate
Download more rows into the grid.
In 2025.2.16 sorting on these columns is allowed. I don’t have data in there to verify it is actually sorting on them, but it sounds like in your case that you don’t even get the sorting arrows.
Could it be that there are more than 500 rows in the grid and you need to download all the records in order to be able to have sorting enabled (I’ve seen that in other places)?
100% This is it! Thank you both for the quick solution!
No kidding. I knew of that issue with filters, but not sorting.
You 2025 people have some new toys… There is no PO section in 2024.2
