John,
Sorry, I forgot to mention there are two ODBC links.
The OBDC link from Access to Vantage - READ ONLY - Open db on server, log
into, and leave running!
Then create a ODBC DSN to the Access DB - ALSO: READ ONLY. Users get there
data from here without
having to log into the Vantage ODBC. With READ ONLY you should not have a
problem with users
corrupting the data.
Also, at our last user group meeting, Kevin Rosell from Epicor mentioned the
idea of possibly putting all the contacts into one table in Vantage. This
would
make things much easier or harder depending on how your populate other
contact lists !!
HTH,
Calvin
Sent: Wednesday, December 08, 2004 7:33 AM
Subject: RE: [Vantage] Can Vantage Customer or Vendor Contacts be
imported or exported to Outlook Contacts?
Hi Calvin,
How do you link Access db to Vantage without have the risk of corrupting
the Vantage Database?
John Mansfield
General Sheet Metal
574 277 0611 x14
Sent: Wednesday, December 08, 2004 2:33 AM
Patrick -
For a one time dump, use the BAM/Export Utility and then map the data
into Outlook.
Also you use an Access DB on the server with link tables to Vantage,
you can create a dynamic link between Vantage and Outlook as well as
Vantage and WinFax. In Winfax you can setup a separate phone book
that is dynamic from Vantage and in Outlook you can setup a separate
contact list that is dynamic from Vantage. This way the user only
needs to maintain the contacts in just Vantage - not both systems.
HTH,
Calvin
Sent: Tuesday, December 07, 2004 3:11 PM
Subject: [Vantage] Can Vantage Customer or Vendor Contacts be imported
Can Vantage Customer Contacts or Vendor Contacts be imported or exported
to
Outlook Contacts?
Has anyone done this?
Patrick Winter
sSc Specialty Screw Corporation
Vantage 6.10.514, Progress 9.1D08, Windows 2003 Server, Crystal
8.5.3.975
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
problem with users
would
contact lists !!
HTH,
Calvin
Hi Calvin,
John Mansfield
General Sheet Metal
574 277 0611 x14
Patrick -
into Outlook.
HTH,
Calvin
to
Outlook Contacts?
Patrick Winter
8.5.3.975
have
and
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
