Canned Vantage Reports to Excel
Excel can read the xml data file with ease (formatting once the data is pulled in can be a challenge though!).
The difference is that excel can't initiate generation of the xml file. Crystal already has the built in integration hooks to trigger the initial required Vantage data export to xml.
We just got service connect - so I'm hoping the BAQ export process BO methods are exposed and we find they can be called from within excel via a vbScript.
Rob
--- On Fri, 12/19/08, Paul Pachniak <paul.pachniak@...> wrote:
Subject: [Vantage] Canned Vantage Reports to Excel
Date: Friday, December 19, 2008, 12:22 PM
We are on Vantage 8.03.0405A, is there a way to take a canned vantage
report (like Engineering/ Reports/BOM Listing) directly to excel like you
can with Crystal reports?
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: Ext. 1114
Fax:
Email: paul.pachniak@ aceprecision. com
<mailto:paul.pachniak@ aceprecision. com>
WWW: http://www.acepreci sion.com <http://www.acepreci sion.com>
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
report (like Engineering/Reports/BOM Listing) directly to excel like you
Paul E. Pachniak
Accounting Manager
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
<mailto:paul.pachniak@...>
WWW: http://www.aceprecision.com <http://www.aceprecision.com>
Since the Progress reports end up as text files in your MfgSysdata or
EpicorData folder, you can use a tool like Monarch:
http://www.datawatch.com/_products/monarch_overview.php
or other such tool.
BTW, BOMListing and BOMSummarized are now Crystal reports in Epicor 9.
Mark W.
P.S. I hope you and your family has a great holiday!
Just yesterday, I found a way that works. There is a 'Method Tracker'
that does not seem to be in the menu system but is accessible from
Part Tracker Revision tab. Select Part # you want, go to REVISIONS
tab, place cursor in REV field, RIGHT click and select METHOD TRACKER.
Select MATERIALS or OPERATIONS tab. This will bring up a grid of data.
You can use mouse to SELECT, COPY then PASTE into Excel worksheet. You
then will need to adjust column widths to see data.
I am on Version 8.03.406A
Bob
> Paul E. Pachniak
> Accounting Manager
> Fax: 262-252-4974
Machining Corp.
