Thanks, yes, we had no “default” receipt warehouse and bin setup. Vantage8 apparently didn’t care but Epicor9 indeed does….Thanks again for your help!
Mike..
Sent: Thursday, February 12, 2015 1:27 PM
Subject: RE: [Vantage] RE: Cannot get into Receipt entry in Epicor 9.05
It has been about 2 years since I went thru the setup, but I believe you need to define default warehouses and bins in the company configuration.
-Phil
Phil Collier | ERP Administrator
[Description: Description: cid:image002.jpg@01CCD052.4A33DBB0]
Dynomax Inc. | Design * Manufacturing * Performance
1535 Abbott Drive, Wheeling, IL 60090| www.dynomaxinc.com<http://www.dynomaxinc.com/>
Main: 847.680.8833 | Direct: 224.207.7657 | Fax: : 847.680.8838
This electronic message transmission is intended only for the use of the person to whom it is addressed, including any attachments, and contains information from Dynomax Inc, which may be privileged, competition sensitive, confidential, or protected by law. If you are not the intended recipient, you are hereby notified that any dissemination, copying or distribution of this email or its contents is strictly prohibited. If you have received this message in error, please notify us immediately by replying to the message and deleting it from your computer.
ITAR Notice: This email may contain technical data which may be controlled by the US International Traffic in Arms Regulation (ITAR) 22 CFT part 120-130. If this data is determined to be ITAR controlled, such data may not be transmitted, shared or provided to any foreign party or entity either verbally or visually without proper licenses from the State Department. It is your responsibility to assure this item can by legally shared with another party. Thank you for your compliance.
