I am getting this error message when trying to import a MES customization.
Has anyone seen this error and know how to fix it?
Regards, John Fellows
I just checked, and, I am still able to import from the āCustomization Maintenanceā Screen. But, I cannot import directly from the MES when in developer modeā¦
did you resolve this problem? I have same situation with Quote Entry form customization. Absolutely same error message
I donāt know why it happens, but I think I had to use the solution workbench to export it in a cab file and then import it.
Try that or maybe do what John did and use customization maintenance?
Ok, I did use import/export (xml file). I need to try CAB
it works through Solution. thx
No problem!
using /MESC launch option correct?
