Can't access PartOpr via ODBC using MS Access
EXCELLENT!
Thanks very much Mark!
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@...
Of Mark Wonsil
Sent: Tuesday, November 28, 2006 10:09 AM
Subject: RE: [Vantage] Re: Can't access PartOpr via ODBC using MS Access
> I am trying to link to the PartOpr table using MS Access via ODBC but
> when I try I get error that says "The size of a field is too large."
> Anyone have any success opening this table via ODBC?
There are usually two errors that I routinely get using ODBC:
- Too many indices
- Field too large
The "work-around", as it were, is to use pass-through queries and only
pull
down the fields that you want. To set up a pass-through query:
- Create new query but don't select a table.
- Under the Query menu item, choose SQL Specific and then "Pass-Through"
- Under the View menu item, choose Properties and set the ODBC
connection
string. (You should be able to browse to it by clicking the ... box on
the
right of the field.)
- Enter your SQL select statement.
That should do it.
Mark W.
Hello,
I am trying to link to the PartOpr table using MS Access via ODBC but when I try I get error that says "The size of a field is too large."
Thanks!
Joe Rojas
I have no problem on 8.00.809 progress db opening PartOpr with Access
2003
--- In vantage@yahoogroups.com, "Joe Rojas" <jrojas@...> wrote:
> Hello,
> Thanks!
> Joe Rojas
I just tried from another computer and I get the same error.
I am connecting to a 8.03.304B Progress DB.
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@...
Of bw2868bond
Sent: Friday, November 24, 2006 10:18 PM
Subject: [Vantage] Re: Can't access PartOpr via ODBC using MS Access
2003
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Joe
> Hello,
> Thanks!
> Joe Rojas
You are correct - I just tried on a 8.03 db and Access gives an error
on PartOpr table.
Sounds like an issue for support....
> Thanks,
> Joe Rojas
> IT Manager
> TNCO, Inc.
> 781-447-6661 x7506
> jrojas@...
Behalf
> Of bw2868bond
Access
> 2003
> Rojas" <jrojas@> wrote:
> > Hello,
but
> > Thanks!
> > Joe Rojas
- Too many indices
- Field too large
The "work-around", as it were, is to use pass-through queries and only pull
- Under the View menu item, choose Properties and set the ODBC connection
string. (You should be able to browse to it by clicking the ... box on the
That should do it.
Mark W.
