I recently added a new company to one of our test environments. The company is up and running, but I can’t print. The print job never makes it to the system monitor. I’ve restarted the task agent. There are other companies that were previously created on the same database. They can print without issues. I found the following in the event viewer:
Error Detail:
The Company column is not valid.
Stack Trace: at Epicor.ServiceModel.Channels.ImplBase1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets) in C:\_Releases\ICE\3.1.500.14\Source\Shared\Framework\Epicor.ServiceModel\Channels\ImplBase.cs:line 775 at Ice.Proxy.BO.SysTaskImpl.Update(SysTaskDataSet ds) in C:\_Releases\ICE\3.1.500.14\Source\Shared\Contracts\BO\SysTask\SysTaskImpl.cs:line 586 at Ice.TaskAgentCore.TaskAgent.<>c__DisplayClass28_3.<CreateTaskInstance>b__5(SysTaskImpl impl) at Ice.TaskAgentCore.ImplCaller.ImplCaller
1.<>c__DisplayClass4_0.b__0(TImpl impl)
at Ice.TaskAgentCore.ImplCaller.ImplCaller1.Call[TResult](Func
2 doWork, ExceptionBehavior communicationExceptionBehavior, ExceptionBehavior timeoutExceptionBehavior)
at Ice.TaskAgentCore.ImplCaller.ImplCaller1.Call(Action
1 doWork, ExceptionBehavior communicationExceptionBehavior, ExceptionBehavior timeoutExceptionBehavior)
at Ice.TaskAgentCore.TaskAgent.CreateTaskInstance(ImplCaller`1 sysTaskCaller, SysAgentDataSet sysAgentData, SysAgentSchedRow agentSched)
Not sure what to try next. Any ideas?
