Have you tried running commander in application mode to see what is happening when the label is actually processed? A lot of times you will get the most information from that. Also have you any errors in History Explorer?
Joshua Giese
CIO
Direct: 920.593.8299
IT Dept: 920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
Wisconsin Converting, Inc.
Sent: Monday, October 20, 2014 9:46 AM
Subject: [Vantage] RE: Can't print bartender labels from live but can print them from pilot
Dataset from Epicor to BarTender, is a custom label that prints from Commander and a trigger.
Use [Epicor905]
Truncate table systask
Truncate table systaskparam
Material Mgmt > Shipping/Receiving > Gen Ops > Customer Shipment Entry > Select a PackID > At this point the Pack is set to shipped and the labels (Ones I created in BarTender) automatically print from BarTender
Patricia Hall
Systems Analyst
[cid:image002.png@...7982E0]
3137 East 6th Street
Muscle Shoals, Al 35661
T: 256.978.6294
C: 256.366.8697
F: 256.383.8224
E: phall@...<mailto:phall@...>
www.cbcings.com
Sent: Monday, October 20, 2014 9:36 AM
Need more troubleshooting steps first, what you described could be a ton of different stuff. Are you printing the labels directly from SQL or a dataset passed from Epicor (it's default implementation from Epicor)? Are you using Commander and triggers? What
did you truncate?
Joshua Giese
CIO
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Sent: Monday, October 20, 2014 9:32 AM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Subject: [Vantage] Can't print bartender labels from live but can print them from pilot
Hello everyone.
I'm running Epicor 905.702a with a sql database and bartender to print my shipping labels. Does anyone have any idea why I'm able to print my labels from pilot but not from my live environment? Or maybe something I can do to fix it? I did the truncate table
command in sql but it didn't clear up my issue.
Patricia Hall
Systems Analyst
T: 256.978.6294
C: 256.366.8697
www.cbcings.com
