Capture standard button click
Kevin, I recommend you approach it from the BPM, as opposed to event code on form controls.
Sent: Tue, May 25, 2010 9:21:14 AM
Subject: [Vantage] Capture standard button click
Does anyone have any sample code where you "capture" a user clicking a standard Epicor button, you do some type of processing, then cancel the button-click based upon your processing.
I can do this with the a button I add, but can't get the syntax on a standard button.
The program I am trying to use is "Start Production Activity", and when the user clicks the "OK" button, I want to do some pre-processing and cancel unless certain conditions are met.
We're on Epicor 9, but I'm sure sample code on Vantage 8 would work as well.
Thanks in advance.
Kevin
Thanks in advance.
Kevin
My suggestion would be to create your own 'OK' button and execute your
code based on that. I am doing the same thing where I am executing a
pre process condition and then completing the transaction with a custom
'OK' button. Just hide the original, remove the tab sequence number (or
jack it way up) and put your own in place. Basically you use the
EpiGUID of the original 'OK' button and call a sub to click it after you
run your own code. See code below as an example.
Module Script
'// ** Wizard Insert Location - Do Not Remove 'Begin/End
Wizard Added Module Level Variables' Comments! **
'// Begin Wizard Added Module Level Variables **
private withevents btnOK as epibutton
'// End Wizard Added Module Level Variables **
'// Add Custom Module Level Variables Here **
Sub InitializeCustomCode()
'// ** Wizard Insert Location - Do not
delete 'Begin/End Wizard Added Variable Intialization' lines **
'// Begin Wizard Added Variable
Intialization
'// End Wizard Added Variable
Intialization
'// Begin Custom Method Calls
'// End Custom Method Calls
End Sub
Sub DestroyCustomCode()
delete 'Begin/End Wizard Added Object Disposal' lines **
'// Begin Wizard Added Object Disposal
'// End Wizard Added Object Disposal
'// Begin Custom Code Disposal
'// End Custom Code Disposal
End Sub
Private Sub StartProdForm_Load(ByVal sender As object, ByVal args As
EventArgs) Handles StartProdForm.Load
'// Add Event Handler Code
txtAssySeq =
CType(csm.GetNativeControlReference("dade67c9-c1e0-49fe-8051-73bb36c8bec
9"), EpiTextBox)
btnOK =
CType(csm.GetNativeControlReference("025fc115-fee3-4973-946e-ba209189d62
e"), EpiButton)
End Sub
Private Sub LaborDtl_AfterFieldChange(ByVal sender As object, ByVal
args As DataColumnChangeEventArgs) Handles LaborDtl_Column.ColumnChanged
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Dim edvSPA As EpiDataView = CType(oTrans.EpiDataViews("Start"),
EpiDataView)
Dim strMES As String =
edvSPA.dataView(edvSpa.Row)("ShortChar01")
Select Case args.Column.ColumnName
Case "JobNum"
txtAssySeq.Focus
edvSPA.dataView(edvSPA.Row)("ShortChar01") = "MES"
Case Else
End Select
End Sub
Private Sub btnOK2_Click(ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles btnOK2.Click
'// ** Place Event Handling Code Here **
EpiDataView)
Dim vRes As String = edvSPA.dataView(edvSpa.Row)("ResourceID")
Dim vJob As String = edvSPA.dataView(edvSpa.Row)("JobNum")
Dim vAssy As String = edvSPA.dataView(edvSpa.Row)("AssemblySeq")
Dim vOper As String = edvSPA.dataView(edvSpa.Row)("OprSeq")
Dim Hooks as Integer = 0
Dim adpJO As JobOperSearchAdapter = New
JobOperSearchAdapter(StartProdForm)
adpJO.BOConnect()
Dim record As Boolean = adpJO.GetByID(vJob, vAssy, vOper)
Dim dsJO As JobOperSearchDataSet = adpJO.JobOperSearchData
Dim dStd As Decimal =
dsJO.Tables("JobOper").Rows(0)("ProdStandard")
Hooks = Math.Ceiling((dstd*60)/17)
'msgbox(dStd)
adpJO.Dispose()
btnOK.PerformClick()
'msgbox(vRes)
If vRes = "PMB" Then
MessageBox.Show("Number of Hooks: " & Hooks)
End If
End Sub
End Module
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of ksimon8fw
Sent: Tuesday, May 25, 2010 9:21 AM
standard button.
well.
Thanks in advance.
Kevin
Hi Kevin,
This is basically what a BPM does. Any reason you're not using a BPM?
Mark W.
Mark,
I would much prefer a BPM solution. However, there is workstation specific
information that we are capturing from the client that is running Vantage,
and I wouldn't have access to that information from the BPM, which runs
server side.
Good thought though.
Kevin
On Tue, May 25, 2010 at 1:05 PM, Mark Wonsil <mark_wonsil@...> wrote:
> Hi Kevin,
> standard button.
> Mark W.
Rob,
Thanks for the idea, I'll give this a shot!
Kevin
> Module Script
> Intialization
> Intialization
> End Sub
> End Sub
> txtAssySeq =
> 9"), EpiTextBox)
> btnOK =
> e"), EpiButton)
> End Sub
> EpiDataView)
> Case "JobNum"
> txtAssySeq.Focus
> Case Else
> End Select
> End Sub
> EpiDataView)
> adpJO.BOConnect()
> 'msgbox(dStd)
> adpJO.Dispose()
> 'msgbox(vRes)
> End If
> End Sub
> End Module
> Rob Bucek
> FAX: (715)284-4084
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf
> Of ksimon8fw
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> standard button.
> well.
> Thanks in advance.
> Kevin
Kevin, I didn't see this until after I wrote the other email.
You can run VB.NET code on the form, tell me a little about what you're doing, maybe I can save you some time by offering my own hit or miss attempts for you to learn from, lol.
----- Original Message ----
Sent: Tue, May 25, 2010 3:52:47 PM
Subject: Re: [Vantage] Capture standard button click
Mark,
server side.
Kevin
> Hi Kevin,
> standard button.
> Mark W.
Kevin -
Try inserting your code into the BeforeAdapterMethod on the Start
adapter.
This code launches upon OK button being clicked. Use the Form Event
Wizard
for the BeforeAdapterMethod. Specifically in the system default code:
Private Sub oTrans_startAdapter_BeforeAdapterMethod(ByVal sender As
object, ByVal args As BeforeAdapterMethodArgs) Handles
oTrans_startAdapter.BeforeAdapterMethod
Select Case args.MethodName
Case "Update"
'place your code here
End Select
End Sub
Hope this helps,
Calvin Dekker
Office: 630-672-7688
Email: calvin@...
http://www.codabears.com
*New software/hardware Support & Maintenance Programs
Of Kevin Simon
Sent: Tuesday, May 25, 2010 4:16 PM
To: calvind
Rob,
Kevin
custom
(or
you
> Module Script
> Intialization
> Intialization
> End Sub
> End Sub
> txtAssySeq =
> 9"), EpiTextBox)
> btnOK =
> e"), EpiButton)
> End Sub
> EpiDataView)
> Case "JobNum"
> txtAssySeq.Focus
> Case Else
> End Select
> End Sub
> EpiDataView)
> adpJO.BOConnect()
> 'msgbox(dStd)
> adpJO.Dispose()
> 'msgbox(vRes)
> End If
> End Sub
> End Module
> Rob Bucek
> FAX: (715)284-4084
> Of ksimon8fw
the
> standard button.
when
> well.
> Thanks in advance.
> Kevin
