Cell Mfg Blank Title 56883
We are looking at combining several operations into a cell so parts can flow from start to finish without having to finish lots and avoiding queue times between ops that don't really exist in the planning process. Question is how are others showing the combined ops on the BOM and routings? We would like to be able to still segregate the materials needed at the various stages with the associated work instructions to complete that portion of the cells activity, then show the next, and so on.
I would appreciate any suggestions anyone might have in this regard.
Thanks!
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
Web: http://www.aceprecision.com/
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
