Change Address on PO Print
Good Day:
RE: Change Address on PO Print
Sun went live on 11/29
in Epicor 9, 9.05.601B SQL-Unidata
Sun was previously on M2K (Manage-2000) 7.0 SP 5 (Informix)
It appears that the Remit address is printed on PO's.
If it has a Purchase Point, the Remit address still prints.
Only way I know is to go through a if..Then.. Else for each line
of the address.
Has anyone made this change? Seems like the form, as is, is wrong
since for a Vendor with a PP, the address on the PO will be the Remit to
( Vendor file - not VendorPP)
Is there an easy way to change that?
Some possiblilities:
1. Both addresses are stored in a child file to the PO. I do ot see
any Addresses in POHeadr file except shipTo. File Name?
2. I sometimes see fields like Rpt1address, Rpt1city, Rpt2address,
Rpt2city, etc. - although I do not see any in Vendor or VendorPP.
3. Another version of the PO-Print some where?
len.hartka@...
<blocked::blocked::mailto:len.hartka@...>
Sun Automation Group
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
