Change BAQ ID in BAQ Report Designer?
Good morning,
I am having a bit of a fog this morning. How can I copy a BAQ Report and change the underlying BAQ ID?
When I copied the BAQ Report the underlying BAQ remained the same. I want to update it to a new version of the BAQ I am working on.
Thanks!
Nate
Is this the new BAQ Report style via Report Data Definition or the Legacy BAQ Report style?
In either case for me its always just export it as XML and then change it via notepad then re-import the XML, most of them have an Export under File or Actions on the Menu.
That did it! I exported the BAQ Report to xml, then found a field called < ExportID >. I changed the name in there to the new BAQ I just made, and it seems to work.
Thank you!
For the record this was with what I assume is the legacy BAQ Report Style. I started by creating a BAQ that had the data I wanted, then I made a BAQ Report out of it. Still using the classic forms in kinetic.
