Hi,
I’d like to change the Bin in Customer Shipment Entry screen based on a UD field. What would be the best object to create this BPM on?
Thank you,
Daniel
Hi,
Thank you,
Daniel
If a default bin is setup for the part, that is what auto populates the bin field on Packer Entry.
To find out what is doing that, enable tracing and then enter a part on a packer. Then go through the trace log to see the BO’s called.
I am aware of the default bin but I would like to change the bin based on the customer. I know the trick to find BO (which I am trying now) I was just been a bit “lazy” and see if anybody already knew the answer.
